Old 12-08-2018, 03:42 PM   #1
Two propane tanks, where to connect Extend-a-Stay ?
My 5th wheel has a propane tank on each side, connected to a single regulator with a switching valve. Where would i install the Extend-a-Stay to use for outside grill?
Rick F is offline   Reply With Quote
Old 12-08-2018, 03:55 PM   #2
I am not familiar with the term "extend a stay" in regards to propane. I have seen and owned several units with a quick connect port to plug in a grill off the rv's propane system. (I assume that is what you are referring to) My currant unit does not have one. I use 1 pound cylinders for my grill. I don't think it would be an easy task to safely add one if your unit does not have it.
Kimber45 is online now   Reply With Quote
Old 12-08-2018, 04:03 PM   #3
A32Deuce's Avatar
I take it you have mounted tanks that don't come off your unit or you want to install the Extend A Stay with a grill by pass. If so, it would go just after the tank shut off and before the unit regulator/tank switch control. That is where mine is on a Class C, but should work for a non removable tank. Hope this helps.
A32Deuce is offline   Reply With Quote
Old 12-08-2018, 04:23 PM   #4
bob213's Avatar
Hook it directly to either tank and then run the existing hose to the regulator. You are trying to avoid the regulator with the extend a stay.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 12-09-2018, 03:30 PM   #5
Old Bleu's Avatar
Yes, I've mounted our Extend A Stay as A 32 Deuce explains on both our Rockwood travel trailer and Cedar Creek 5er. Never been a problem.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 12-09-2018, 08:43 PM   #6
Thanks to all for the info. I will mount on the tank before the regulator....
Old 12-11-2018, 07:30 AM   #7
DouglasReid's Avatar
We run both an outdoor grill and a three burner Cast Iron tabletop stove. Both can run simultaneously.
My camper came with one quick connect that was inline after the regulator. In other words it was already reduced pressure propane at the disconnect.
I re-positioned the original quick connect from directly below the RH propane tank to the rear near the entrance steps. I also added a second quick connect beside it.
Each appliance came with its own regulator. They were designed to connect directly to a propane bottle. I removed the hoses from each appliance and replaced them with hoses with no regulator.
Now I only have to plug in the hose for each appliance and I have a large supply of propane for either or both, No worries about small disposable bottles or 5 gallon tanks clattering around in the storage area.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
propane, tank
