Old 09-09-2013, 09:56 PM   #11
BurgPath's Avatar
I've filled a low tank.
Why wait on that last little bit to go and run out. They only charge you for what they put in at a refill station.
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 09-10-2013, 11:17 PM   #12
dcheatwood's Avatar
I run til empty. Local propane co charges flat rate to fill a bottle.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-11-2013, 12:03 AM   #13
Taranwanderer's Avatar
I'm with you, Cheat. Run one until its empty, switch over to the second. Then you know you're officially half full (or half empty, I guess.) I use this method for the RV and for my two 100# tanks that run my house generator. I also have one of those gauges from CW that you install at the tank valve, not sure how accurate it is but better than nothing. I've also heard that you can pour a bucket of warm water over the tank and see where the frost line forms to tell how much LP is still in the tank. Haven't tried that one yet.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-11-2013, 10:08 AM   #14
BurgPath's Avatar
I thought it was cold water? Oh well.
DCheat that stinks. Local UHaul fills them like a car gas tank. Fill it till it overflows and read the meter.
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 09-11-2013, 11:47 AM   #15
Denver, CO
garbonz's Avatar
either cold or warm works as long as you are using significant propane at the time, eg that stove, furnace, or HW heater. Its the propane evaporating at the surface of it's level in the tank that creates the frost line. Its the same for the magnetic strips by the way.
2017 Fuse 23T
Old 09-11-2013, 06:42 PM   #16
dcheatwood's Avatar
Yeah, I bought a partial tanks worth years ago at royal gorge, and it only took a few pounds to fill. Charged me some odd amount like $7.15.
Old 09-12-2013, 12:06 PM   #17
I've filled a partially empty tank before a long trip. Propane places here fill by weight and charge accordingly so I only paid for the propane they put in the tank.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 09-12-2013, 12:21 PM   #18
mjones12's Avatar
I think Herk posted something a while back that said if your furnace quits due to an empty tank, you'd have to pull and replace the furnace fuse to get it to reset. That would be an unwanted task in the middle of the night. Herk, please correct me if I misunderstood your explanation.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 09-12-2013, 02:44 PM   #19
All I would have to do on mine is turn it off briefly at the thermostat, but I can't say what Herk would need to do on his (or you on yours; why not turn the tank off and find out.)
Old 09-13-2013, 12:42 PM   #20
Helmsey's Avatar
I still use the infrared temp gun I carry to check the propane levels. It works well for determining where the propane is in the tank, and I already have it with me for tires\hubs while traveling.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
