Old 05-10-2014, 01:54 AM   #1
Water Heater leaking propane
I arrived at my campsite with my 2013 Cataline.The Dealership did a substantial reskin job over the winter due to hail damage. When I opened the propane tanks it became readily apparent, from the gas smell that the techs had removed a gas supply hose to the water heater and not reconnected. We have no heat now as I have the gas turned off at the bottles. I dont dare run the furnace. Is there a shutoff for the gas line specific to the water heater? I would like to at least have some heat...
mtnbound is offline   Reply With Quote
Old 05-10-2014, 04:52 AM   #2
Witch Doctor's Avatar
I have never seen one yet. Why can't you connect the gas line back up to the water heater?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-10-2014, 05:34 AM   #3
Glen,I hope he is OK,after he posted at 3am? He needs to take it back to that dealer,and have it Fixed. I think he should go to a Safe place while the dealer works on it also! This could have been a Very Bad post,and not by Him? Youroo!!
Old 05-10-2014, 05:41 AM   #4
It also brings to mind why the (Propane Safety valve) didn't shut off a direct propane Leak? Youroo!!
Old 05-10-2014, 06:22 AM   #5
Very true youroo on both post. To be honest I think I would be looking for a different dealer myself.
Old 05-10-2014, 07:06 AM   #6
KyDan's Avatar
Propane safety valves shut off hi flow but not entirely. They still allow small
amount when tripped in the "safe" position.
My gas grill will occasionally trip the in-tank safety valve if I spin the
valve handle ON too fast. I can still light the grill but I get a low flame.
Also have had the same thing in the trailer. Stove burner will light but it's
low flame.
A dealer who left a gas line open is not a dealer I'd want messing with my rig!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-10-2014, 09:25 AM   #7
Thanks to all for the quick responses! I cant re-connect as there seems to be a piece missing. There is no gas line coming out of trailer into the compartment outside rear of the TT. Not that familiar with this heater but was hoping there was a gas shutoff valve at the rear of the trailer. Was also wondering if gas only flows to the heater unit when the
Tank heater is turned on??
Old 05-10-2014, 09:32 AM   #8
TURBS's Avatar
no shut off
All lines are full of propane pressure regardless of device or item.
Old 05-13-2014, 11:05 AM   #9
You are 100% correct about the shutoffs. I am including a photo for educational purposes for those still not 100% sure.... The gas line was pushed back during repairs, through the heater panel under the bed compartment which also houses the water heater etc. Best access is by removing the mattress and plywood base(screwed down) and pushing the line back out through the rubber liner in the photo. It was re-attached , checked and all is fine. Line pressure check for leaks and system checked out fine...
Since there are no shutoffs between appliances and the propane bottles I recommend checking this connection on a regular basis!
Many apologies from the repair shop......
Ready for the May long weekend!
mtnbound
Old 05-13-2014, 11:13 AM   #10
VinceU's Avatar
Looks like they pulled the copper line back and has the cap you need. If you can locate the loose line underneath maybe you can put it back through the hole and connect it.
I hope!
Sorry, day late and dollar short!
heater, leak, propane, water, water heater
