Old 03-23-2014, 06:38 PM   #1
Webber Baby Q Low Pressure Hose
I want to hook my Baby Q to the quick disconnect on my Prime Time Crusader.
1. I know I can't use the regulator that is on the Baby Q.
2. What are the exact connectors I have to use to make up the proper hose.
3. So that I can also use the Baby Q at home off a 20lb how can I do that. (I know I need to use the regulator for that.
Has anyone done this? As popular as the Baby Q is I have to believe it has been done.
2013 Crusader 260RLD-TE
2011 Ford F250 Super Duty - 4WD - Lariet - 6.7 Diesel
Rickflint is offline   Reply With Quote
Old 03-23-2014, 06:40 PM   #2
davel1971's Avatar
http://www.amazon.com/Weber-6501-Ada...s=weber+q+hose
this will hook it up to your cylinder and solve 1 of your problems.
David & Lynn
Old 03-23-2014, 06:54 PM   #3
Originally Posted by davel1971 View Post
I should have been more clear. I know I have to remove the regulator to use a low pressure hose with the Baby Q. I don't want to have to put the regulator back on the grill just to use it at home only to take it back off to go camping.
I was thinking of a way I can put a quick disconnect directly on the grill and then have two different hoses to attach to it. ONE for low pressure when camping and a SECOND with a regulator on it to use with the 20lb tank.
I have the hose you linked to, and use it at home off a 20lb tank.
Old 03-23-2014, 06:58 PM   #4
davel1971's Avatar
gotcha. I made up a hose a used it off my Wildwood (traded it) last year and used with the regulator. Yes, you are running through 2 regulators. It works, but not how it should.
David & Lynn
Old 03-25-2014, 08:59 AM   #5
So know one has the exact parts needed to convert a Baby Q to a low pressure quick disconnect?
Old 03-25-2014, 04:45 PM   #6
There has been a thread on this in the past to do exactly what you what. Try a search and see if you can find it.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 03-25-2014, 09:26 PM   #7
Sent you a PM.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
pressure
