Old 02-12-2016, 09:16 AM   #21
MNtraveler's Avatar
What temp causes propane to stop flowing properly?
Originally Posted by MOODMAN View Post
Just a thought, but if you are concerned about it, you could put your propane tanks in a heated compartment.
Propane cylinders should never be put inside the unit. It's a code violation and extremely unsafe.
Now come all the replies saying I have done this for years and never had a problem. That proves nothing. Ask a gas expert or a firefighter.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-12-2016, 10:32 AM   #22
Having lived in the far north all of my life l have had to deal with propane in very cold conditions. In this area anyone that uses propane to heat their houses have electric tank heaters on their tanks.
That being said it is the regulator that will give you freezing problems and because of the changing of state from a liquid to a vapor that causes the regulator to be very cold the more propane you are using the more chance it will freeze up.
One trick that is used with success is to place a trouble light by the regulator the incandesant bulb will create enough heat to keep it from freezing. I realize this is not a good solution for dry camping.
Doug
Gee Force is offline   Reply With Quote
Old 02-12-2016, 11:34 AM   #23
Global Nomad
Scheinin's Avatar
I just purchased Cedar Creek 36CKTS which has 2 30# propane tanks. I and my wife are living in the unit full time. I am now caught in the Maryland snow storm. Last night the temperature was 9 degrees. No problem with propane flow for my heating and water system. Tomorrow the temperature is expected to go down to 4 degrees. I am more concerned with my water. The Creek has the arctic package, but that is advertising.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 02-13-2016, 03:45 PM   #24
I use LP for the kitchen range in my home in Maine. We hit 35 below zero and everything worked fine.
Harold Fay is offline   Reply With Quote
propane
