Old 09-16-2012, 04:55 PM   #1
Briorick's Avatar
What type Lp gas indicator do you use, or recommend?
Hey All, the reason I ask is we just got back from a weekender and our Lp went dry unexpectedly. I looked at the Lp tank before heading out and it read approx. 1/2 full but after just 1 full day it went dry. We don't use the propane much other than making coffee and heating water. The, new to us, furnace ran a few times during the night, 5-10 minutes tops each time, so I can't imagine it would have sucked that much propane. But anythings possible. We had the thermostat set at 60, as we tend to like it cooler.
Back to the Lp indicators. I noticed on another 20 lb. tank I had just re-filled, and knowing it was full b/c I watched the guy fill it on the scale, the indicator on this tank only read 1/2 way on the green color indicator as well. The Lp indicator on that tank is brand new. Now I'm wondering if these Lp indicators are less then reliable. On my other Pup I had the numeric measure level indicator which I liked much better than these color coded ones. Anyone else have problems, and also what type are you using for accuracy readings.
Here is a link to the ones I am referring to.
Amazon.com: Mr. Bar-B-Q Propane Tank Level Gauge: Patio, Lawn & Garden
Thanks All.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 09-16-2012, 06:02 PM   #2
Trailer Trash
Just installed 3 of them yesterday on my RV. They were 9 bucks each at Menards.
They work on pressure not volume so they will not tell you how much propane is left in your tank. I expect them to work like a gas guage in an old car. She runs on full forever then once the needle starts dropping, it bottoms out quick. Sooooo, when the guage is NOT on full, that should be your clue to lift a tank out and refill it. When it gets to bottom part of green or yellow, probably too late.
Here is another picture of what they look like.
joelek is offline   Reply With Quote
Old 09-16-2012, 07:35 PM   #3
Briorick's Avatar
Thanks joelek,
It would be interesting to know when you FILL your tanks if your needle goes all the way to the top or stops at mid-point over the wording "Gas". I bought 2 of these ( brand new ) and both when "fully filled" indicate that the tank is 1/2 full in the green zone. I know they are full b/c I watched the guy fill them on the scale.
When I had my older Lp indicator on my last Popup, it had the 1/4/, 1/2, 3/4, and full indicator ( which showed it being FULL ) and was most accurate. These not so much.
If, and when, you fill your tanks I would be interested in knowing of how the gauge indicates. Maybe this is the new norm for these Lp indicators. So we adjust. Sheesh! Thanks again.
Rick & Brian
Old 09-16-2012, 08:03 PM   #4
Broadway Joe's Avatar
They work on pressure not fluid level. In hot weather they tend to read top of the scale, at lower temps they will read mid to low. The only accurate methode is to weigh the tank.
Broadway Joe is offline   Reply With Quote
Old 09-16-2012, 08:11 PM   #5
Trailer Trash
They are a 9 dollar piece of Chinese made you know what. Full is subject to interpretation. Remember these are pressure guages. When the pressure drops from were the guage needle has been sitting for days your tank is getting close to empty.
Here is another secret - those swap em out gigs where you give us your old tank and we give you another tank all nice and shiny and full. Well those cleaned up tanks only have 15lbs of propane not 20lbs. They don't fill them all the way full when they reconditon the tank. Ya got ripped off. But hey, your exchange tank is all cleaned up, has new white paint, and a brand new label on it. Makes people feel good when they open up their BBQ or RV and see a new white tank.
Old 09-17-2012, 02:00 PM   #6
Wanna Be Camper
SaskCampers's Avatar
Maybe so, however it is a good deal if your old tank is tx'd. It saves you paying 25 or 30 bux for a new tank as they have the new cert dat stamped into the top ring here in Canada anyway. I do that when I get a tx'd tank then just get it refilled at COOP when empty.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-17-2012, 06:42 PM   #7
Trailer Trash
What is a tx'd tank? Assuming that is on old trashed out one or an old one without the over pressure valve. IF you have a crapped out rusted out old tank, the exchange gig is a great buy. If you have a good tank and she is just empty, go get it refilled.
You Canadians must have special rules with propane. The Columbus 320RS model I have had 4 20lb tanks in 2012. Now they have 3 as they roll off the assembly line. Evidently having 80 pounds of propane was a no no in Canada so the Columbus recieved a design change. I have the 3 tank model and honestly it's just fine.
Old 09-17-2012, 07:08 PM   #8
Yukon Don's Avatar
I believe tx'd = time expired.
Canadian tanks have a date stamped into them, good for 10 years if memory serves (actually I have to learn this stuff better myself now...).
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 12-11-2012, 10:56 AM   #9
w4drr's Avatar
As others have said, those gauges are strictly pressure gauges. Propane in the tank is a liquid held under pressure. That pressure is constant (except for temperature variations) until the last bit of liquid propane has evaporated in the tank. That is why a pressure gauge gives you little warning until it is too late. The same exact principle applies to CO2 fire extinguishers, as pressure gauges are useless on them also. They must be weighed to determine how much liquid CO2 is in them.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
w4drr is offline   Reply With Quote
Old 12-11-2012, 11:55 AM   #10
nuisance's Avatar
For a rough guess take a cup of hot water. Pour it down the outside of the tank. After a few seconds you'll be able to feel with your hand where the tank goes from hot to cool. That's the level of the gas.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
