Old 12-28-2018, 09:05 PM   #11
They are Rego valves. 7647sc 3/4"NPT connection. the valves are like $25.
shoooey is offline   Reply With Quote
Old 12-28-2018, 09:12 PM   #12
Usually Confused Member
emm-dee's Avatar
Thank you very much. Just found it on Amazon. Looks like a perfect replacement.
https://www.amazon.com/Rego-Propane-...k+filler+valve
2018 Forester 3051S (aka Clyde)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 12-28-2018, 10:07 PM   #13
Assistant TP Supervisor
B and B's Avatar
Are you replacing this yourself?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 12-28-2018, 10:12 PM   #14
NMWildcat's Avatar
Yep. I would definitely go to a propane dealer/distributor and have them replace it.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 12-28-2018, 10:32 PM   #15
emm-dee's Avatar
No. Iím a little slow but not yet at a complete stop. Turning metal on metal with a big wrench next to propane is not something Iím comfortable with.
Old 12-30-2018, 10:15 AM   #16
fmjnathan's Avatar
Call the manufacturer...they have been very helpful to me.
fmjnathan is offline   Reply With Quote
Old 01-02-2019, 03:58 PM   #17
Old Enough to Know Better
gasman6674's Avatar
That will be a stop fill valve probably ceodeux (V13414 manchester tank Part#)
RegO makes fill valves but they don't make stop fill valves.
That valve has a float in the tank that shut off the flow. the valve is installed on the 80% line of the tank to prevent overfill and yes most of them are a POS.
Contact your local LP gas dealers (not refillers like pilot/loves) and see if the will order and install for you. i would be bitching to the dealer but i understand your reasoning.
Good Luck
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 01-13-2019, 12:22 AM   #18
emm-dee's Avatar
Update...project complete. Went by two propane dealers and was told by both that they fill MH tanks but do not work on them.
One of the places was kind enough to demonstrate on one of their tanks how to remove the valve. They said my valve was probably one with the overfill protection device which has a history of high failure rates.
Yep...that’s what it was.
That valve was installed with the “top” marker indication offset about 30 degrees. That alone would stop the fill at about 65 percent, and worse if the MH was parked nose down during filling. The dealer pointed out that that was probably the problem but since there was no way to test the fitting it should be replaced. Since the tank comes with a pressure relief fitting the OPD setup is redundant. I replaced it with the standard “Rego” brand valve and all is well now.
Many thanks to Shoooey for pointing me in the right direction.
Old 01-13-2019, 05:34 PM   #19
SailorSam20500's Avatar
Out of curiosity, what is the secret to removing the valve safely? Wondering what the dealer who gave you the advice said. Glad you got it taken care of.
Al
Save the Earth. Itís the only planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 01-13-2019, 08:30 PM   #20
Head Rambler
I'm glad you got it changed without incident. And now you can finally get a full tank.
Gotta go campin!
