Old 03-02-2019, 07:21 PM   #1
Retired Old Fart
dward51's Avatar
Wood chip in flare fitting for appliance!
If you are having LP issues with any of your appliances, you may want to examine the interior of the flare fitting. This is what I found inside the flare to my Dometic refrigerator line in my 2015 Freedom Express 246RKS today. I presume it has been there since the trailer was made as the original polyurethane sealant was on the rubber LP line.
I mean really!!!!
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
dward51 is offline   Reply With Quote
Old 03-03-2019, 10:24 AM   #2
SeaDog's Avatar
Cleanup during the MFG stage has never been something the factories excel at.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-03-2019, 10:56 AM   #3
SecretSquirrel's Avatar
Yep, I don't think any regular visitor here is going to be surprised which is sad that's the state of affairs.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 03-03-2019, 11:06 AM   #4
nomad297's Avatar
This sort of thing isn’t uncommon for any type of construction — new, old, house, condo, commercial and RVs. It happens. There’s not much that can be done to keep the occasional foreign object from getting into a pipe during construction every now and then. It doesn’t matter how clean you try to keep a workspace — it happens.
Bruce
Old 03-03-2019, 11:24 AM   #5
SailorSam20500's Avatar
I remember my parents house. Had basement floods for years every time it rained hard. A plumber eventually snaked the line from the gutter entry (before that was outlawed) and pushed out a 6" piece of 1x2. No more floods.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 03-03-2019, 11:35 AM   #6
nomad297's Avatar
Yup! I run across this sort of thing all of the time. I will remove construction debris from customers’ water pipes and drains that have been there for years/decades. This is not really in the same realm, but just this past Friday, I fixed a leak on an old cast bronze 1/2” 90 where both sides of it were never soldered when the house was built in 1958.
Bruce
Old 03-03-2019, 11:44 AM   #7
Cabinfever97's Avatar
When we had our house built there was wood debris that came out of every fixture. Would have probably never known except the flow reduction in the faucets caught it.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
Cabinfever97 is offline   Reply With Quote
Old 03-03-2019, 03:01 PM   #8
DouglasReid's Avatar
Bruce
Similar thing here. 3 months after our current house was finished the toilet in the Master Bathroom quit filling, ONLY fixture to do so.
The plumber found sand in the angle stop. Had to have gotten in there when the plumber who put the lines in before the slab was poured let sand get in them.
He isn't in business BTW, mine wasn't the only house he screwed things up in.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-03-2019, 06:31 PM   #9
rlh1957's Avatar
You'd be surprised at the stuff pulled from water and drain lines in building construction. Sometimes right away sometimes discovered years later when a problem occurs... wood chips, metal and screws, screwdrivers, a wrench, soda cans, trash, dirt, stones.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 03-03-2019, 07:50 PM   #10
Lorenc
Yup we bought a house from my wife’s grandmother built in 1959, slow drain in bath vanity,
Took 1 1/2 galv trap apart below and found an old pair of pliers half gone from rust!!
lorenc is offline   Reply With Quote
Old 03-03-2019, 08:00 PM   #11
I've been extremely surprised watching my oldest sons new house being built these last few months. The builder has signs all over the interior instructing all contractors to clean up "DAILY" before leaving the job site. Son goes in almost daily and I've been with him a couple times and I've looked in the new plumbing, electrical, HVAC and I've been amazed by the lack of debris in any of mechanical systems in the construction phase...really amazed.
TheWolfPaq82 is offline   Reply With Quote
