Old 10-04-2012, 06:41 AM   #21
That picture was taken strictly to illustrate where the Antifreeze inlet was located. I can see how someone could get confused if they did not take everything in its entirety (i.e the combination of my text/pictures and responses from other members within the thread). Regardless, enough of this bantering as I am sure that people have more important posts, which require answering. Take care.
Brian Lahner is offline
Old 01-24-2013, 08:17 AM   #22
cllecr's Avatar
We are also winterizing for the first time and I came back here to review this thread. We do not have an antifreeze inlet siphon hose off the water pump (one dealer told us it would be over $100 to have one installed), so we poured the antifreeze into the fresh water tank and pumped it through the system from there, being sure to open all taps including inside and outside showers.
I did not see anything saying to redrain the tanks, assumed it would be good to have some antifreeze in each?
The only other glitch was not being able to get the anode rod out of the water heater ...assume that is necessary to completely drain it!
Scott and Carol
2011 Sunseeker 2300
Life is an adventure!
new to us RV owners April 2012
2012- 100+ days camping + Panama cruise
2013- 60 nights in our RV so far (as of Aug 1)
cllecr is offline
Old 01-24-2013, 09:42 AM   #23
I would say by pouring A/F in F/W tank and using the pump without draining the H/W tank you have wasted your time,and Diluted the A/F in the F/w system. Remove plug in heater,bypass and try agin,with a adaptor on the suction side of the water pump! Youroo!!
youroo is offline
Old 01-24-2013, 01:25 PM   #24
cllecr's Avatar
We have the water heater bypass in place so no water going to or from it into the plumbing....correct? We assumed that if we got the correct socket wrench (1 1/16" apparently, although we could not find this in the manual)....we could remove the anode and any remaining water would drain from the water heater at and from that point? Am I missing something? How would it dilute the system?
Scott and Carol
2011 Sunseeker 2300
cllecr is offline
Old 01-24-2013, 02:21 PM   #25
Jmjtx's Avatar
I too used the FW tank with pump to circulate RV antifreeze. I used it for several years and never had a problem. I had to use vise-grips and then used a crescent wrench to break it loose. Seemed too tight from dealer. I want to get the siphon sometime and try that. It seems to be the preferred method by many veteran RVers. Good luck!
Jmjtx is offline
Old 01-24-2013, 02:22 PM   #26
Jmjtx's Avatar
Oops, used vise grips on anode rode.
Jmjtx is offline
Old 01-24-2013, 02:36 PM   #27
I am getting out of this Post,Vise Grips,Pink in F/W tank,I will get back in the Post in the spring? Youroo!!
youroo is offline
Old 01-24-2013, 02:42 PM   #28
Herk7769's Avatar
If you got it out; replace it. Once the flats on the anode are damaged you will just make it worse trying to get it out next time.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 01-24-2013, 04:21 PM   #29
Capt. Mike's Avatar
The Camco 36543 RV Pump Converter Winterizing Kit is available on Amazon.com for $14.95. Installation is very simple - it goes in the line on the freshwater tank (inlet) side of the water pump, and takes only a few minutes to install, depending on how easy your pump is to access. Once installed, it remains in place permanently, so next year's winterization is very easy. We put one on our boat and could do the entire water system (two heads, transom shower,galley and ice maker) with just a couple of gallons of "pink", in a very short time. I can see a dealer charging $100 bucks for the part and installation, but it is really very easy to install.
You do need to by-pass the water heater, get the annode out (1 1/16" socket with about a 3" extension) and drain out any anti-freeze that has gotten in there before you turn the water heater back on next year. That rotten-egg smell that sometimes gets in the water system is from bacteria, and heating that anti-freeze seems to either cause it or, certainly, makes it worse.
Mike
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline
Old 01-25-2013, 05:22 AM   #30
cllecr's Avatar
Originally Posted by Capt. Mike View Post
The Camco 36543 RV Pump Converter Winterizing Kit is available on Amazon.com for $14.95. Installation is very simple - it goes in the line on the freshwater tank (inlet) side of the water pump, and takes only a few minutes to install, depending on how easy your pump is to access. Once installed, it remains in place permanently, so next year's winterization is very easy. We put one on our boat and could do the entire water system (two heads, transom shower,galley and ice maker) with just a couple of gallons of "pink", in a very short time. I can see a dealer charging $100 bucks for the part and installation, but it is really very easy install.
Mike
Excellent. Since we are heading home now, we will have a mailing address we can access so I could order this and install it before we need it again. Can be challenging finding such things on the road.
Am I going to need any special equipment to dewinterize?
Scott and Carol
2011 Sunseeker 2300
cllecr is offline
