Old 01-25-2013, 03:43 PM   #31
Capt. Mike's Avatar
Scott,
You are not going to need any special equipemnt to de-winterize, but flush all lines - both hot and cold - at all faucets - until the water runs clear BEFORE you open the water heater by-pass valves. Also, if you've gotten the Camco winterizing by-pass kit in by then, we used to take a gallon jug of white vinegar and run it through all of the lines via the winterizing by-pass, just to flush out all of the lines each spring. After everything runs clear, put the anode back in thewater heater, open the w/h by-pass valves, and make sure it is filled with water before turning it on. (open the pop-off valve on the water heater for a second and you can tell that the water heater has filled.)
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline
Old 01-25-2013, 04:11 PM   #32
B47
Originally Posted by herk7769 View Post
If you got it out; replace it. Once the flats on the anode are damaged you will just make it worse trying to get it out next time.
I agree with Herks advice to replace it with a new one. Most rods require a 1 and 1/16" socket to properly remove and reinstall the rod.
I suggest you keep one and the necessary racklet (sp) and extension to allow you to get to the rod end in your tool box.
B47 is online now
