Old 05-06-2013, 02:05 PM   #1
KyDan's Avatar
Here is a link to photos of the process to replace your heating element-
Suburban water heater electric element R&R
Home Depot no longer carries the camco 1500 watt 120v element.
They have others but they are long.
Update- March 2017
Found this at Lowes.com
Utilitech Water Heater Screw Element
Item # 146227 Model # 9008069046
$9.78 in stock at MY local Lowes store.
The photo appears to be the short version which should fit an RV water heater
very nicely.
Remember- you want a 1500 Watt 120 volt -short- screw in element.
Good Luck!
You'll also need a special deep socket to fit.
Just search Home Deopt or Lowes for water heater element socket.
These are typically around $7. You don't need an automotive heavy deep socket
that costs $20 unless you already have one in your tool box.
They do have a 2000 watt 120v heater but it would draw about 16.6 amps.
That would clearly trip a 15 amp breaker.
The 1500 watt 120v heater should draw about 12.5 amps which will work
very nicely.
FYI I removed the cover and visually checked the fusable link on the
T-stat/hi limit switch. It is good
Last time about 3 years ago, when heater blew for unknown reason
(maybe close lightning strike) it took out the heater AND the fusable
link on the t-stat/hi limit switch.
Here's a YouTube video how to change the element.
BE SURE ALL ELECTRICAL POWER AND LP GAS IS OFF BEFORE ATTEMPTING
TO REPAIR YOUR WATER HEATER!!
and happy camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now
