Old 04-21-2008, 05:11 PM   #1
08 roo 21ss front bunk door delaminating
I have an 08 roo 21ss i havent even used it yet.I noticed yesterday on the bottom of the front bunk door about 2" up all the way across to the corners and then about 6" up on both sides is de laminated .I don't no if its always been like that but does not seem correct maybe water geting in.
4runner is offline   Reply With Quote
Old 04-21-2008, 05:38 PM   #2
Rockinwood's Avatar
Take it back and get repaired while under warranty, Somtimes the glue comes apart, could be water though, take and get repaired before it gets worse, make sure you check the whole trailer to make sure there is no more delam,
I had a Keystone bfeore I got the Rockwood, I made the mistake of calling the Delam as minor, when the unit went Out of Warranty the whole front end cap bubbled.
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 04-21-2008, 07:47 PM   #3
Look like this, this is only an 8 day old camper?
Name:	Copy (3) of Collins delam 1.jpg
Old 04-21-2008, 08:54 PM   #4
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Fiberglass sure looks nice, and is easier to clean....
but I sure love my aluminum sides! (although my Keystone never had issues with delam)
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 04-22-2008, 04:07 AM   #5
The problem with fiber glass is that there are more things that can go wrong while in production which requires a better Quality Control Program. Things like the adhesive material, the vacuum equipment and the environment in which the work is being performed in ( dirt, temp and humidity control need to be watched ) The aluminum is more durable but I think it is a little harder to clean.
