Old 08-18-2016, 09:26 PM   #1
13' windjammer cracked plastic
On the outside of our slides there is a black 90 degree piece of plastic at the wall/floor corner. The side is under a white channel screwed to the side of the slide. The bottom of the trim is adhered to the bottom of the slide. The black olastic 90 is cracked on nearly all 3 slides. What advise is there of the repair. I thought of having black aluminum bent to a 90 and replacing the plastic
Laona is offline   Reply With Quote
Old 08-24-2016, 10:35 PM   #2
These are called "wear strips" or slide out plastic by Forest River. Had to replace them on one slide which was pretty straight forward. All you need is some butyl tape, and something to jack the slide up about an inch or two to give you space to remove and place the new part.
LH p/n 10-03354A, RH 10-03356A, cost me $10.52 ea last year.
I wouldn't spend the effort to try and fabricate anything with replacement parts being this cheap.
I ordered my through Forest River support. Hope this helps.
TT 2011 Rockwood Windjammer 3008W
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Anderson WD hitch
cobiker is offline   Reply With Quote
windjammer
