Originally Posted by 007matman
Careful with the EternaClean.
First ingredient is Acetone. Not compatible with plastic.. learned that the hard way.
If you want to clean the roof prior (and I would recommend that) just use Acetone. Be careful not to get it on plastic though.
and use Nitril gloves when you do. You DO NOT want that on your skin
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
