Old 03-18-2019, 10:47 AM   #1
1st time roof repair
Backing into camping spot I scuffed the roof, see attached photo, what is the best method to make repairs? 2017 XLR NITRO
twentz is offline   Reply With Quote
Old 03-18-2019, 10:51 AM   #2
007matman's Avatar
You can either lay down a bed of self-leveling Dicor or use some Eternabond tape.
I'd measure how wide you'd need. By the look of it 6" should be good but I can't see everything in your photo.
I just installed Eternabond this weekend on my camper. Simple to install and I understand it'll last as long as the roof does.
007matman is offline   Reply With Quote
Old 03-18-2019, 10:54 AM   #3
007matman's Avatar
Here's the 6" stuff.. it's what I used on my front roof seam.
10' long.
WHITE Eternabond Mobile Home RV Rubber Roof Repair 6" x 10' - 10 Foot, 10 Feet https://www.amazon.com/dp/B077SHW98Q..._e87JCbE388NMQ
Old 03-18-2019, 01:53 PM   #4
47driver's Avatar
Eternabond until it's time to replace the roof.
1989 Viking Li'l gasser Pop up
1993 36’ Thor Class A
2009 16” Kodiak Cub Hybrid
2010 24’ Fleetwood Pegasus
2017 24’ Flagstaff Shamrock 23IKSS
2015 Ram 3500 Diesel MegaCab 4X4 SRW
47driver is offline   Reply With Quote
Old 03-18-2019, 02:01 PM   #5
Herk7769's Avatar
I agree. Prep with Eternabond Cleaner, then spray on some Eternabond Primer.
A nice wide application of Eternabond Tape that will completely cover all the damage will make a lifetime permanent repair.
Herk
https://www.bestmaterials.com/Search...ategoryID=1021
HAM CALLSIGN - KC3FFW
Old 03-18-2019, 04:30 PM   #6
Thank you very much for all the great advice.
Old 03-18-2019, 07:05 PM   #7
007matman's Avatar
Careful with the EternaClean.
First ingredient is Acetone. Not compatible with plastic.. learned that the hard way.
If you want to clean the roof prior (and I would recommend that) just use Acetone. Be careful not to get it on plastic though.
Old 03-19-2019, 01:48 PM   #8
DouglasReid's Avatar
and use Nitril gloves when you do. You DO NOT want that on your skin
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-19-2019, 02:40 PM   #9
What everyone said about Eternabond.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 03-19-2019, 07:19 PM   #10
After...
After you apply the Eternabond, roll it out with a roller, pressing firmly. You do not need the expensive roller they sell. A $2 wallpaper seam roller from Lowes will work fine. You could even borrow a rolling pin from DW if you think she won't get too angry.
Larry
Larry-NC is online now   Reply With Quote
repair, roo, roof, roof repair
