Old 07-16-2019, 02:34 PM   #1
Exclamation 2020 Coachmen APEX 293RDLS UPDATE
I want to provide an update on our TT since we have had more time with it. First we have no leaks after the flashing was installed that the factory left out.
Other items to look for we discovered in order of concern. We discovered the underside of the slides have screw points coming through the floor. I found out after one caught the flooring while opening the slide and tore the flooring. I got under the slides and used a Dremel to remove all the points. We now need to have the floor repaired.
The stabilizers are mounted POORLY, only one side has screws, no welding, so you cannot use them as intended. If the TT is not perfectly level they will simply bend the stabilizer and off it goes. Bad design. We used blocks and pyramid screw stands until I can get it resolved.
The tires are China Bombs, changed them to Goodyear Endurance.
We are trying to find someone to do the warranty work since we are no longer in Florida where we bought the trailer. Having a heck of a time getting our dealer to help with this need. They never call back after promising to find us a place to have the work done. Beware of dealer promises for help while on the road.
Updates later.
usarmyretiredsgm is offline   Reply With Quote
coachmen
