Old 08-14-2014, 03:33 PM   #1
mwoods's Avatar
A little rot Puma 30QBSS
Discovered a rear corner of the slide out had a soft spot.
It was damp when I found it. Not wet, just damp to my fingertips.
I pulled off the damp OSB that was rotting, so it has been at it for awhile.
The area was about 6 inches wide and 12 inches in length.
I had repaired the roof of the slide out about 10 days ago so I think this dampness was left over from that, at least I hope so.
I dried out the area, sprayed it with bleach water and dried it again.
A trip to Ace Hardware and 20 bucks later I was ready to patch the area.
I placed a cement block on the floor above this area.
My fix was to rip a scab board a 1 1/2" wide by about 15 inches long. The board is 3/4" thick, it fit perfect with the OSB.
I screwed the scab board in place.
I cut a 6"X16" piece of old flooring.
I placed that up to the damaged area, and then filled the void with expanding foam. I placed the board against the flooring then glued and screwed it into place.
I sealed the board with SticknBond and the edges of that with Dicor.
It looks waterproof, and if there is still a leak, I can feel inside on the carpet to see if it is damp.
Hopefully this takes care of the problem and I did open and shut the slider a few times and the repair job does clear the area it slides into. The DW helped as she pushed the slider button....
TV 2012 Chevrolet Silverado CC 5.3
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
mwoods is offline   Reply With Quote
Old 08-14-2014, 05:13 PM   #2
Plain Old Member
On a majority of slide floors, the factories do a piss poor job. Run water down the end of the slide and watch what the water does. That might answer your problem. A lot of campers have some of the end if the slide floor exposed with maybe a little paint on it. Might work for a year, or not at all. Any little break in that and it's a sponge. Even on some of the slides with the darco fabric, some manufacturers secure the walls by screwing through the darco fabric underneath and leave a hole. The water will run 2-3 inches up under the slide before dropping and those exposed holes act as wicks too. Plenty of discussions on this forum about this issue. Also, that 1 inch trim strip at the bottom on each end of the slide can be the culprit. Sometimes insufficient sealant tape and sealer was used, and the water can wick in the screw holes.
Sent by ME
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-14-2014, 05:22 PM   #3
B and B's Avatar
BiJjohn,
I have to disagree with your statement regarding my trailer. There are slippers on the edge the slide, which area attached to the slide walls with moulding screwed and caulked. The underside is plastic. No exposed wood to be seen. The water rolls and drips off the slippers. I had 2 replaced at Goshen this year that are cracked.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-14-2014, 08:50 PM   #4
Plain Old Member
Yes, on some there are, but not all. I never said ALL units are like that. Wildcat for one had exposed wood, or a painted edge in that area, at least the ones I looked at. The OP's does not appear to have the glides under the floor.
Sent by ME
Old 08-14-2014, 08:56 PM   #5
Plain Old Member
I'm well aware of the plastic glides. I was one that posted the contact info in another thread for the Majestic glides used on ours. The thread about the wearing darco. I had to add them to mine as Cedar Creek does not use them.
Sent by ME
Old 08-15-2014, 07:47 AM   #6
mwoods's Avatar
Got a heck of a rain storm this morning, was really pouring here at the house.
Checked the TT and there was water under the corner on the SticknBond like BigJohnD said happens.
Checked the interior and it is bone dry.......
So the repair is doing it's job so far.
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
puma
