Old 05-21-2015, 04:25 PM   #1
AC maintenance
Any one do any routine maintenance to your AC like cleaning the coils? Have never attempted it just looking for some suggestions to help keep it in top operating condition.
TN2TRAVEL is offline   Reply With Quote
Old 05-22-2015, 03:22 PM   #2
Never Leak RV Roofing
Change out the a/c gasket, clean out drain holes then take and blow out the dirt from coils ect.
rvroofer is offline   Reply With Quote
Old 05-25-2015, 12:01 AM   #3
A/con maintainence
Remove the cowling...about a dozen screws, usually. Use your favorite dirt/degreaser/cleanser in a spray bottle and hit the grime. Wipe clean. Now you'll have a better view of things...check wire connections for tightness and cracking or fraying...clean the fan blades and lubricate the fan motor shaft...inspect tubing for any rust or coolant leak...spray the coil with foaming coil cleaner, available through any of the big box stores...let it do its thing and rinse thoroughly...make sure, at this point that drain holes are running clear...if there are cooling fins that are bent or flattened, use a small, wooden skewer or a coil comb to reset them...careful, they're fragile...now reinstall the cowling (you cleaned this as well, didn't you). Go inside the trailer and open up the unit...inspect the foam filter...if dirty clean in warm, soapy water, rinse, dry and set aside...inspect duct work...you don't want cross ventilation leaks...reseal gaps with metal duct tape if necessary, then reinstall the filter. Using a flashlight take a peek into your ac ducts...make sure everything is well connected. You're done. Enjoy your revitalized unit.
slipf18 is offline   Reply With Quote
Old 05-25-2015, 09:48 AM   #4
Evereddie's Avatar
Anybody found an upgrade to the foam filter. Seems a little chinsey to me, especially after a couple of seasons use and many washings.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 05-25-2015, 10:14 AM   #5
Stormrider151's Avatar
In addition to what has ben said in other posts. Check your mounting bolts accessible from inside your trailer. Over time they can loosen. They shouldn't be very tight but snug. To tight and the seal will be lost.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-25-2015, 01:01 PM   #6
Thanks everyone for the info and tips. I guess they are no longer tips but hacks. Anyway I appreciate all the advise. Maybe tackle this next week. Thanks
Old 06-03-2015, 09:57 AM   #7
I believe I have a leak from my rear AC based on staining on the vinyl ceiling and wet light sockets aft of the AC unit. My rig sits in the drive with a downward rear slope and the staining is from the AC to the rear/end of rig or about 14-16 inches. All outside seals are perfect so I can only guess that the water is from the AC. Besides the 4 mounting bolts, which I tightened twice, snug as previously suggested on the class A thread, but not knowing how tight is snug? If I remove the cover, is there any other type of sealant around the outside AC mount that would need sealing?
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 06-03-2015, 10:02 AM   #8
Witch Doctor's Avatar
You can go to lowes they sell a green filter like 20x20 then cut it to size will last a lot longer, or just cut a high eff. filter down to size and stuff it up there. will be tight but will work when you remove the 1" frame.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-03-2015, 10:06 AM   #9
Crockett's Avatar
DONT seal the outside perimeter. the base pan has holes and water needs to drain. replace gasket. the only maintenance the needs to be done on a newer
coach is clean the filter once a week when in use. slipf18 is right on...but maybe after a few years..unless your a chain smoker with a pekinese...
Crockett is offline   Reply With Quote
Old 06-03-2015, 01:25 PM   #10
Evereddie's Avatar
Looks like that's what I will do. Thanks.
maintenance
