Old 10-04-2018, 10:45 AM   #1
handymanj56's Avatar
aerospace 303
has anyone tried this aerospace 303 uv protectant?..if not good, what does anyone suggest to use for protecting my rv from the elements ...wax? I have the fiberglass siding.
thankyou
handymanj56 is offline   Reply With Quote
Old 10-04-2018, 11:04 AM   #2
Hi,
I have used 303 for years -- on not just my slide seals, but whitewater rafts and other kinds of gear exposed to UV.
Highly recommended by this old guy...
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 10-04-2018, 11:06 AM   #3
Thankyou
Old 10-04-2018, 12:06 PM   #4
Amazon, gallon, on auto refill. Started using it years ago to keep a Jeep top flexible and alive. Works well on the plastic windows too.
RV, nearly everywhere and often.
2016 SS 2250 E450
Dp26 is offline   Reply With Quote
Old 10-04-2018, 12:19 PM   #5
Love 303. They make wipes as well for dashes and such.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2019: 34 nights camped
Teamfour is offline   Reply With Quote
Old 10-04-2018, 10:31 PM   #6
WFD
Wax will last much longer but wax shouldn't be applied to decals. I use 303 on decals and plastic parts and tires. Works great. Brings back the black on plastics beautifully. Trick is, less is better. Otherwise it streaks. You will need to re-apply every few weeks as per their instructions. Also works great on my tonneau cover on the truck...Amazon has great pricing on it.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-04-2018, 11:20 PM   #7
Tundra 2014
303
I use this stuff on kayaks to prevent UV fading. The color now is the same as it was new-8 yrs. I also have used it for 10 years on auto and trailer tires to prevent cracking. It was made for aircraft tires for the UV protection. I tried it on slide seals and got some sticking, but I may have put it up wet. I do not use it for seals anymore.
Tundra 2014 is offline   Reply With Quote
