Old 10-28-2011, 11:36 AM   #1
(Kim)
Labzy's Avatar
Another winterizing question.....
What do you guys/gals do for the furnace vent openings?
Do you cover them with anything?
Also, I have seen people take the refrigerator cover off, put a plastic bag to cover the opening, then put the cover back on.....does anyone here do that?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 10-28-2011, 11:41 AM   #2
TURBS's Avatar
I never have covered furnace opening. Good idea. If I was to do it id use painters tape over it.
I store mine inside so not real important other than mice but they'll chew through steel bars.
bag idea is good to!
Old 10-28-2011, 01:12 PM   #3
Wanna Be Camper
SaskCampers's Avatar
I put plastic over the fridge opening and then put the cover back on. THis is due to something I think Crocus brought up last year about how they only put silicone or what ever the sealant is on the lower edge of the opening and of course snow will blow in and almost fill that area and when it melts you get the side walls wet on the inner skin. Putting plstic over it and then the cover back on prevents snow from getting in the opening. I saw this first hand last winter so I blew it all out and then started with the plastic.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 10-28-2011, 01:34 PM   #4
Triguy's Avatar
John - Good point about the plastic over the fridge opening. Although I never noticed a problem, I could definitely see this as a problem.
Kim, I've heard of people doing just what you described with their A/C because of stories that snow blew in and somehow got into their trailer, which caused damage in the spring. Again, I've not had the problem in the past, but others have.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-28-2011, 01:46 PM   #5
(Kim)
Labzy's Avatar
The trailer next to mine at the storage facility has his fridge done like this......just thought I would ask and see if it was OK to do. =]
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
