Old 09-22-2010, 09:18 PM   #21
BigDTx's Avatar
Originally Posted by The_Stuff View Post
is it worth joining? probably will be my only purchase.
probably not if it will e a one time purchase.
BigDTx is offline   Reply With Quote
Old 09-22-2010, 09:44 PM   #22
Villa Estate 392FLFB
The_Stuff's Avatar
15$ for a year and the washer/dryer is couple hundred cheaper with discount so i think i will save some money and let them pay for my membership lol
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-22-2010, 10:02 PM   #23
grhodes50's Avatar
I found condensation on my bathroom vent, just one side about 2" diameter. It wasn't too bad but did cause a slow drip. I called the shop and they told me there is no actual duct work for the AC. The styrofoam insulation is in sections and it has pre-cut groves for the duct works. I removed the inside trim and two sections of the styrofoam met at the point where I found the condensation. I could feel cold air from the AC blowing through.
Gary & Trish
2018 Nights Camped - 5
Old 09-24-2010, 10:59 PM   #24
jimh's Avatar
Originally Posted by Danielflading View Post
I believe they make a specific product for this and it is a foam vent cover.
may not help alot with condensation but it will certainly keep out the heat.
I have alseo see them in a thicker style I think 6" foam adn they slip up into the vent opening.
REFLECTIVE VENT THERMAL INSULATOR - 3IN FOAM INSULATION...Regularly $15.29 On Sale for Only $12.77
RV Roof Vent Insulator/Covers on Sale
yep, that looks like it would work well. the aluminum will block the infared in the summer and it seales...kinka like insulation over an a/c duct. interupt the circulation of warm moist air, and it should stop raining.
jimh is offline   Reply With Quote
Old 09-25-2010, 09:22 AM   #25
Hipshot's Avatar
I had condensation on the inside of the vent cover over the bed at night last winter 35 outside 60 inside. I opened the vent a little and turned on the fantastic fan in the bathroom to low, no more condensation.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 09-30-2010, 06:46 PM   #26
Water Damage to RV interior
When I discovered condensation in my shower skylight thats what the dealer tried to tell me also. No worries thats normal! Yea right. So after my RV set at the dealer for 90 days they finally had it picked up by the manafacture in Indiana. Well they had to replace both sides and the top on my RV due to severe water damage. The interior was ruined. This was a brand new RV I purchased in May 2009 and had only been camping in it twice. The dealer told me they had 3 other RV's that also had to go back due to water damage. Well I just got my RV back in August and it looked great! Well the manafacture just picked it up this Tuesday and hauled it back out to Indiana because there was water in the underbelly storage unit again! This is so depressing.
satkins is offline   Reply With Quote
Old 09-30-2010, 08:11 PM   #27
jimh's Avatar
that's a little bit different ball game. there shouldn't be a flow of warm moist air in that area (between the roof skylight and the ceiling skylight). there are two skylights there. when i found water drops in my tub, i went on top and resealed the skylight around the roof. a couple months later, when it leaked again, i found a small crack in the outside shower skylight moving from edge to center (abt 2"long). i sealed that and haven't had any problems sense. this winter i am going to go back up and drill a small hole at the end of the crack to stop the spread and seal it again.
Old 11-04-2010, 08:34 PM   #28
The_Stuff's Avatar
Well the cushions arrived today. lets see how well they work i guess!
Old 11-04-2010, 09:58 PM   #29
I would also put that shrink-wrap plastic over/on the vent frame, like the stuff they make for the inside of house windows. Otherwise the moisture will just go through the 'pillow' and freeze/accumulate on the vent top. And it will ACCUMULATE, until a warmer day when it will all melt and come down at once!
Old 11-04-2010, 11:14 PM   #30
The_Stuff's Avatar
Good to know!
