Old 10-06-2013, 09:45 PM   #1
Awning
How do you adjust awning alignment? Electric awning and when in the frame don't line up with frame on side of camper. Thanks in advance!!!
Cardinal camper is offline   Reply With Quote
Old 10-07-2013, 07:08 AM   #2
jtstromsburg's Avatar
This is usually caused by the awning material sliding in the roller channel. Many on here, have pulled the material back to center, verify operation, and then put a large diameter pop rivet thru the material into the roller to hold it.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-07-2013, 07:21 AM   #3
Thanks! I'll check and definitely try that. Sounds like a likely problem.
