Old 08-18-2015, 01:54 PM   #1
strut526's Avatar
Awning Tape to repair holes- review
I paid $20 for the Camco Awning Tape at the RV dealership and it would not stick to the underside of the awning. I washed the area, used rubbing alcohol like the directions stated. it came off within a couple days.
So I went to the local hardware and bought the "Gorilla Glue Tape" ($8) and so far it has held up to weekly open and closing of my awning. (I repaired 4 holes or small slits) I also had a wear mark on the awning from the door opening, from lowering one end of the awning during rain. Otherwise it shouldn't touch the awning! I put a strip of the tape over the wear mark to keep it from getting worse.
Hardware,Walmarts and I believe Joann Fabric sells it...if so, you can use a coupon!
http://www.amazon.com/Gorilla-602700.../dp/B00EUGCT22
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 08-19-2015, 05:31 PM   #2
We use the same stuff for emergency whitewater raft repair. PVC raft fabric is probably the same material type as the awning fabric, so perfect solution and cheap.
prestonj12 is offline   Reply With Quote
awning, repair
