Old 10-20-2017, 01:07 PM   #1
Bad stains on Lamilux finish: help!!
Good afternoon!
I have searched the forum for a way to clean bad stains on the walls of our Windjammer.
What do you use on fiberglass to first: get the old wax off and second: get the stains out (including black stains coming down from the window frames), before putting new wax again. Sorry no pics as TT is stored right now.
Thank-you very much for your help!!
grangalo is offline   Reply With Quote
Old 10-20-2017, 01:11 PM   #2
ejohnson1144's Avatar
I've had good luck with rubbing alcohol
ejohnson1144 is offline   Reply With Quote
Old 10-22-2017, 03:24 PM   #3
Thank-you as you're the only reply I got!!
Old 11-01-2017, 12:11 AM   #4
Try Meguiars RV Rubbing Compound, followed by their RV Polish then RV Wax.
Preferably applied with a radom action orbital buffer and appropriate pads.
Also, a Mr. Clean Magic Eraser may work.
Good luck!
IslandVic is offline   Reply With Quote
