Montana Boars Hair wash brush. You can get them at AutoGeek.com. If you go with a synthetic fiber brush just make sure the ends of the bristles are flagged. Any telescoping handle will work with it. Use a good pH neutral wash. Honestly, Meguiar's Gold Class wash from AutoZone is as good as any. Then I recommend a good sealant over wax. It lasts longer and provides better UV protection. I use Pro-Tec Sealant Polish. It's designed for gel coat.
If you really want to speed up the washing process get a foam cannon.
2020 Ram 2500 Laramie Longhorn 6.4
2015 Flagstaff 27VRL
