Old 11-11-2013, 08:52 PM   #1
Black dots,removed finish
Recently had black dots on my rv,when removed with wet sponge, the spots came off, but so did the finish. Do not know what they were from. Anyone have any ideas? Is there any kind of touch up,fiberglass paint finish.
gasp1 is offline   Reply With Quote
Old 11-11-2013, 08:56 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Where were the dots? Front cap, sides, rear?? And how large were they? Do you have a picture? Did they come off with just water, or did you use something else?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 11-11-2013, 09:18 PM   #3
They were only one side of camper. Just used dawn detergent and came off. They were only the size of a pinhead.
Old 11-11-2013, 09:29 PM   #4
Lloydg's Avatar
Sounds like either a bug or tree dropping. Have you tired using a good fiberglass polish to rub the area with?
Old 11-11-2013, 09:52 PM   #5
Thanks for the info. I'll try the fiberglass polish.
Old 11-11-2013, 10:15 PM   #6
Evereddie's Avatar
I get that too. Either bugs or tree drippings like was said in post above me. A real drag when it happens.
Evereddie is offline   Reply With Quote
Old 11-11-2013, 10:22 PM   #7
RalphieAdie's Avatar
It's spores from the mulch bed that is near your unit. The spores can fly up to 10 feet. They come from using black mulch. If you change to cedar mulch (more expensive) you won't have the spores. We've fought the spores for years, first on our house (white siding), now on our truck and 5'er! HATE IT!!!
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 11-11-2013, 10:29 PM   #8
Phat Phrog Stunt Crew
awwall's Avatar
I would be very cautious about using Dawn on your fiberglass. Have read some bad things about using it. Try to find a detergent made for fiberglass...
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 11-12-2013, 12:47 PM   #9
5erDriver's Avatar
Yep. It's called artillery fungus and shoots toward the sun, or in your case, mine and many others a bright surface. Google it. It is a pain to get off. I have found NuFinish scratch remover from the auto store to work good. Small orange plastic bottle. I dabbed a little on the spots with a microfiber, left for a minute and went back and they come off. Still need a little elbow grease tho but does not damage the finish. If you can get a good coat of wax on the camper they come off way easier. Good luck.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 11-12-2013, 12:48 PM   #10
5erDriver's Avatar
And get rid of your pine mulch or switch to cedar or rubber or its a losing battle.
black
