Old 06-26-2019, 09:38 PM   #1
Bubble skylight condensation.
I have a 2018 E-pro 19fd with bubble style skylight over the bathtub. I'm getting condensation in between the inner glass and the outside bubble that has no place to drain. Anyone seen this or have a fix for this? Thanks.
Suke2U is offline   Reply With Quote
Old 06-27-2019, 04:06 AM   #2
Lame *****
I saw it on my last camper. Ended up being a roof leak. Was a mess for me.
Does it show after showers or when sitting?
Maggot is offline   Reply With Quote
Old 06-27-2019, 05:33 AM   #3
007matman's Avatar
I think some condensation is normal if it's cold outside and warm inside (or vice-versa). Mine does it when we are using the shower.
If it's not being used and collecting water you have a problem and inspecting the Dicor around the outside would be your first step.
007matman is online now   Reply With Quote
Old 06-27-2019, 05:46 AM   #4
jeff64's Avatar
Run a bead of silicone bathtub caulk around that outer bezel against ceiling. Take bezel down and dry/clean both surfaces 1st.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-27-2019, 06:59 AM   #5
Lame *****
Here is what I did to my dome immediately when I got my new rig home.
Used Eternabond cleaner and taped, Dicor lap sealed and Trempro 645 on the vertical spots.
Not the prettiest site but functionally is should help in the long run. Still will require PM and up keep.
Old 06-27-2019, 10:05 AM   #6
Thanks for the feedback and ideas. I don't think it's a leak because it forms at the top of the bubble and runs down. It happened all winter while I was living in the unit here in SC. There's very little insulation in these units, so there's a big temp differential in winter. I think I'm going to take out the inside shield, run eternabond tape around the inside of the opening, replace the inside then run the bead of silicone around the lip after I put it back. This should help make it more airtight and hopefully reduce the problem. Thanks again!
light, skylight
