Old 04-27-2016, 01:02 PM   #1
gstrohecker's Avatar
Bubbles On Roof
I have a 2015 Rockwood 8289WS that's a little over a year old. Went up to clean the roof and noticed bubbles or blisters in the roof. Anyone else have this problem?
ID:	106309   Click image for larger version
gstrohecker is offline   Reply With Quote
Old 05-13-2016, 07:10 PM   #2
roof bubbles
new 2016 wildcat went on roof and found bubbles, now what?
liveoakfl is offline   Reply With Quote
Old 05-13-2016, 07:17 PM   #3
Flybob's Avatar
Many times these are just spots where the adhesive used to hold on the roof was thin or missing. Usually they will come and go with temp and unless they are very large or very loose, it is best to leave them alone. The only real way to correct them is to remove and completely replace the roof. This is usually not authorized. Occasionally they are repaired by puncturing the bubble and inserting some adhesive. This voids the warranty and compromises the integrity of the roof. I would take pictures send to the dealer to document and keep a eye on it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-13-2016, 07:19 PM   #4
crunchman12001's Avatar
Hi,
Most of the time the bubbles are really just sawdust, staples and debris that was left stuck in the adhesive before they laid the rubber down creating the bubble.The pics posted appear to have small spots, not to worry unless they get very large or penatrate the roof membrane.
Edit. The most important thing while you are up on the roof, check all the roof caulking for cracks or areas that look like the caulking is coming lose. Re-apply Dicor self leveling sealant to those areas.
2015 F-250 FX4
Old 05-13-2016, 07:51 PM   #5
Cyber Phrenologist
Radio's Avatar
I tend to agree with leaving them alone especially if there are no leaks. They may go away after some time. I would keep and eye on them to see if they get worse.
I had 2 bubbles on mine. They eventually went away.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-14-2016, 07:35 AM   #6
FR and Alpha have assured me they are not a "problem". Never had any on previous 5ers.
Old 07-23-2016, 10:34 AM   #7
Good luck with these small bubbles. 4 years ago I thought same thing, no problem. However, I now have huge bubbles that are going to require a new roof. Of course been too long now so warranty doesn't apply. Not sure there is any way to keep these small voids from progressing to larger bubbles.
dan.beilman is offline   Reply With Quote
roo, roof
