Old 03-04-2014, 10:04 AM   #1
Bumped the gutter extension
I bumped the gutter extension on the edge of an overhang the other day. Not hard enough to rip it off, but enough to separate the caulking. What kind of caulk is that up there? I'm going to have to re-seal it.
RoyGBivUV is offline   Reply With Quote
Old 03-04-2014, 10:20 AM   #2
Old Enough to Know Better
gasman6674's Avatar
Silicone I believe not the paintable type
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 03-04-2014, 10:42 AM   #3
VinceU's Avatar
Suspect Dicor self leveling sealant used at installation. Much better adhesion to rubber roof, EPDM etc.
Old 03-04-2014, 11:19 AM   #4
F/R factory does NOT use Silicone for roof area sealant! The sealant they use? They gave me some at the Fac. but NOT available for retail sale! Dicor is a product that most members use. There is (Vertical & Horizontal) types select the proper one,self leveling is not for Vertical apps. Youroo!!
Old 03-04-2014, 01:08 PM   #5
Isn't the gutter spout on the gel-coated wall, not the rubber roof? Same sealant?
Old 03-04-2014, 02:23 PM   #6
gasman6674's Avatar
PS I like your screen name, took a minute to sink in
Old 03-27-2014, 09:28 AM   #7
'RoyGBivUV" noted that the item damaged was a "gutter extension". This would be on the side of the unit. I agree that the Dicor sealants made for flat surfaces is very good but in this case wouldn't a silicone sealant, non-paintable at that, be a better sealant? AI installed gutter extensions on my unit and used a silicone sealant on these. I'm not sure how the Dicor, especially the 501 Dicor, would work on a vertical surface.
Thurman is offline   Reply With Quote
