Old 10-05-2014, 12:10 PM   #11
Islander's Avatar
I suppose it depends on what you call 'winter'
.... in the Pacific Northwest we get a wet winter and some snow, not the 5 to 6 feet of snow as some might think.
I used a full cover on my previous 5th wheel and only left 1 vent "slightly" open...just a crack.
Here ..the winter temps do dip below freezing so I always left a heater inside that would come on at 3 to 4 degrees above freezing.
Also when the trailer is closed up for the winter I leave a "Stor-Dry" unit running. It combats mold, mildew and dampness by circulating the air with a 'low' heat continuously....fan and heat element draw 90 watts.
I did all this to combat any moisture problems and it seemed to work.
However, if your 'winter' is in a area of temperatures that do not go below freezing... I would definitely want to leave all the roof vent open a certain amount for air circulation.
-Islander-
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 10-05-2014, 12:40 PM   #12
camper1999's Avatar
Originally Posted by bend302 View Post
X2 Have them on both vent fans (including a fantastic fan) and we love them.
Bill
X3 the other is a waste of money in my opinion
2011 GMC 2500HD Diesel
Old 10-05-2014, 03:59 PM   #13
indybp57's Avatar
Originally Posted by rockfordroo View Post
Slight theft of thread: Do those of you with vent covers leave the vents open or closed when you put on your trailer cover for the winter?
Open. And we do get well below freezing here in central Indiana.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 10-05-2014, 07:26 PM   #14
Should have also mentioned that I have no power available while in storage. Also no maxxair cover, so I'd have to put a 2x4 or something under the vent cover before installing the ADCO cover.
2011 Traverse LT, 3.6L, FWD
Old 10-08-2014, 09:52 AM   #15
Windywest's Avatar
In our area on the SW Alberta prairies, it's dry, dusty, and windy. I keep my vents closed in the winter, and have never had a problem with condensation. If I left them open even a bit, we'd have a layer of fine dust everywhere, and then I'd have to deal with a mad wife.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 10-09-2014, 10:58 AM   #16
mud yapster's Avatar
We have the vent covers over all our vents and leave them open while at home but I close them while traveling just to help keep the dust down inside.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-09-2014, 04:15 PM   #17
WFD
I installed the MaxAir 11's on all our vents, 2 powered and 1 not...no issues and an easy install....other than being able to keep vents open, it also helps to protect the factory vent covers...plus helps keep some sunlight out.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-23-2014, 08:20 PM   #18
brownie289's Avatar
[QUOTE=Islander;714107
-[/QUOTE]
Do tell what is a stor dry?..
2015-26days, 2014-32days,
2013-33days, 2012-30days
brownie289 is offline   Reply With Quote
Old 10-24-2014, 08:55 AM   #19
Islander's Avatar
The "Stor-Dry" (Click for web link) is a 110 volt small low power draw fan/heater.
For my size of 5th wheel I should have 2 Stor-Drys running, but as mentioned (above) I have another heater set to come on at just above freezing temperatures.
In warmer climates perhaps the Stor-Dry is not necessary when unit is stored.
Hope this helps.
-Islander-
Old 10-24-2014, 09:36 AM   #20
Denver, CO
garbonz's Avatar
I take my create a breeze cover off entirely for the winter so the camper cover fits better. I like the create a breeze vent cover cause it has a high flow rate (according to their tests) and it pop's right off with 4 clips.
It's called Fan-tastic Ultrabreeze Vent Cover and it is a little bit more $$$ as any higher quality product would be.
2017 Fuse 23T
cover, vent
