Old 10-24-2014, 09:40 AM   #21
Denver, CO
garbonz's Avatar
Originally Posted by blsst16 View Post
I had a leak in my bathroom vent. When I tried to take the vent cover off (fantastic vent w. Fantastic vent cover), it had gotten stuck in the sealant around the vent. In the process of wrestling with it, I put a small tear in the roof, so I had to fix that as well. Got the leak fixed and decided to leave the cover off altogether. I am not impressed with how the vent and cover were installed and sealed. I suppose if I get ambitious, I could clean up the old sealant and do it better.
Sent from my KFSOWI using Tapatalk
Somebody used to much sealant on the install and that is what stuck on the edges. I carefully work the cover off when I cover the camper it in the fall, and while I am inspecting the whole roof and then clean and apply a little bit of dicor where needed. Someday when this becomes to much of a chore I will probably do the whole roof with eternabond, but now for awhile.
2017 Fuse 23T
Old 10-24-2014, 10:39 PM   #22
Canadian Member
itat's Avatar
Here is a video that gives you an idea of how smaller vent covers, including the MaxxAir II, affect air flow on a Fantastic Fan. The MaxxAir II is demonstrated at 1:12 in the video.
http://www.youtube.com/watch?feature...&v=p1fhkbl_1yQ
Camco's website for the MaxxAir II says, "Can be safely installed over high powered RV ventilator fans; however our Fan/MateŽ is specifically designed for this application allowing higher air flow from your existing ventilator fan." So, yes it can be used over higher powered fans like the Fantastic Fan but it's not the best option.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 10-25-2014, 11:43 AM   #23
brownie289's Avatar
Wow that's a very cool demo....
2015-26days, 2014-32days,
2013-33days, 2012-30days
brownie289 is offline   Reply With Quote
cover, vent
