Old 06-03-2019, 07:49 PM   #1
scayne62's Avatar
Can I Eternabond?
Can I put Eternabond on the seal flange and trim on the outside edge of the slide over it and the screws?
scayne62
2020 Heartland Torque 371
2019 Silverado 3500HD DMAX
https://www.epgsoft.com/visited-stat...00&format=jpeg
scayne62 is offline   Reply With Quote
Old 06-04-2019, 10:02 AM   #2
cardwellmarty's Avatar
Can you post a picture of what your wanting to repair?
cardwellmarty is offline   Reply With Quote
Old 06-04-2019, 10:16 AM   #3
This is where l placed Eternabond on our slide outs, covered the flange and screws l think you are questioning about.Click image for larger version
ID:	206407Click image for larger version
Old 06-04-2019, 10:16 AM   #4
scayne62's Avatar
I have attached a pic with an arrow pointing to the area, it currently has butyl tape under it but I do not want to disassemble to put more in so thought maybe I could eternabond it.
scayne62
Old 06-04-2019, 10:17 AM   #5
scayne62's Avatar
I have also put it there, just wondering about putting it down the vertical flange as well.
scayne62
Old 06-04-2019, 10:25 AM   #6
I use Dicor lap sealant on mine some use Pro flex, but to answer your question, yes Eternabond could be used probably 4 inch wide, as long as you just cover the flange on the vertical wall and don't let the Eternabond get where the slide out seal meets the outside of the slide when it is closed because it would not be level and would possibly cause a leak.
Old 06-04-2019, 10:37 AM   #7
scayne62's Avatar
Thank you for the replys, I also have some proflex, maybe that would be easier to use.
scayne62
Old 06-04-2019, 10:44 AM   #8
Yes it would be easier and not that water can not enter there would be less app to since its vertical and not flat. But uf you decide to use Eternabond the application would be no different than the flange l covered on our slide out on top horizontally. Good luck with your repair.
Old 06-06-2019, 05:25 PM   #9
Originally Posted by cardwellmarty View Post
This is where l placed Eternabond on our slide outs, covered the flange and screws l think you are questioning about.Attachment 206407Attachment 206408
Any problems with it leaking with that beefed up eternabond job? Thinking of placing some here as well.
Csvt18 is offline   Reply With Quote
Old 06-06-2019, 06:19 PM   #10
No, l have placed Eternabond on every seem now except roof vents and sewer vents, l removed each of them and placed two layers of Butyl tape and Dicor self leveling caulk let the Dicor set about a week and placed a second layer of Dicor. I did not put Eternabond on my vents because they may need replacing, and l know two layers of Dicor is an over kill but it has been two years and all still looks good. But the key is two layers of Butyl tape, factory puts one layer and its not enough, l also put two layers of Butyl under my windows, l had 6 leaking no problems after repair.
eternabond
