Old 12-12-2016, 09:22 AM   #21
Different units have different roof construction so a "fits all" answer doesn't apply.
I'm 250 # and walk on my Flagstaff with no problem except where the A/C ducts are. You can feel the roof give slightly when you get over one of the ducts that are channeled into the roof.
On a SOB unit I did like Mr. Havercamp and used 2" foam blocks about a foot square.
I made four of them, put under my hands and knees and crawled around.
You could always buy a pair of these...
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 12-12-2016, 02:07 PM   #22
Comox Valley RV
Originally Posted by Dc8mdtmech View Post
I've read a few times that if a ladder is installed, then the roof has been reinforced to support additional weight. I use a trash can to store my cover. When taking it off DW collects the cover compresses the sides and top together until all is in the trash container. Come install time the back comes out first. Simply bunch a bit up, tie a short lite rope and throw the rope up. I then pull the rope and cover onto the unit front to back being careful not to walk on the covers. Watch for wind, and DW ensures the sides are free of the mirrors. Pretty simple using this method, once again watch the wind,the cover is a big sail.
The ladder, for the most part, is optional equipment. The units are all built the same, some get ladders installed. The important connection points for the ladder isn't the roof, but the rear wall it's screwed into. The roof will be constructed the same way regardless.
I would never recommend using the ladder screwed to the RV unless you have no other alternatives. Buy a good sturdy 'A' frame ladder to climb up for inspections and repairs. And, as mentioned previously, be careful up there!
Canuckshaw is offline   Reply With Quote
Old 12-12-2016, 02:09 PM   #23
Comox Valley RV
Those are pretty skookum!
Old 02-14-2017, 08:11 PM   #24
I'm 330... I have walked on my Sandpipers roof a few times...
2010 Ram 1500 4x4 5.7 Hemi
2017 Sandpiper 376BHOK
dritson84 is offline   Reply With Quote
Old 02-15-2017, 09:26 AM   #25
Wolverine 1945's Avatar
Those would also work well when going to the Mail Box !!!
Wolverine 1945 is offline   Reply With Quote
roo, roof
