Old 10-21-2011, 01:02 PM   #1
Iowegian's Avatar
Caulking / putty used on sides of trailer?
Hello,
Does anyone know what material the factory uses when mounting bits and pieces to the vertical surfaces of our trailers? (butyl rubber tape?) I recently replaced a baggage door catch and the sealant behind came off cleanly. I was able to roll it around in my palms before flattening it out and reusing it. I would like to replace some of the other areas to make them look better, and may also attempt the LED tail light project. Thanks!
2011 Rockwood Ultralight 2304S
2010 GMC Sierra 1500 CC
Iowegian is offline   Reply With Quote
Old 10-21-2011, 02:40 PM   #2
If it removed cleanly, and rolled up like "play doh", it was butyl tape. Some use that, and some use it and then caulk also. Hope this helps
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 10-21-2011, 09:27 PM   #3
kevinC's Avatar
Originally Posted by Iowegian View Post
Hello,
Butyl tape is the best and lasts the longest, but you can also use plumbers tape. For RV use it comes 1" wide and about an 1/8" thk.
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
