Old 11-10-2013, 11:38 AM   #11
I think I am going to use the EternaBond it sounds pretty maintenance free thanks for the replies.
RickV is offline   Reply With Quote
Old 11-10-2013, 02:36 PM   #12
chiefly1's Avatar
I would like to know how it turns out. I did the Dicor over the top of the existing caulking after cleaning it and it turned out good. Not sure I want to keep adding more Dicor every year...
chiefly1 is offline   Reply With Quote
Old 11-10-2013, 09:06 PM   #13
Ordered it on Amazon today will probably put it on Thursday or Friday. I will let you know how it goes.
Old 11-10-2013, 10:02 PM   #14
Incheon, S. Korea
BigBaron's Avatar
As a former commercial waterproofing contractor, I recommend removing all old sealant. You wouldn't paint over old paint that is starting to peel, would you? I also like to see why things are cracking or leaking.
I use silicone sealants because they will outlast the trailer. I use butyl tape under lights, etc., because it can't fail unless they come loose.
Regardless of what you use, surface preparation is key.
Clean with alcohol and a rag, and wipe dry with a clean rag. Do not let the alcohol dry before you wipe it!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
