Old 11-05-2013, 06:10 AM   #1
Caulking Question
I plan on cleaning my roof tomorrow. While I was up there inspecting it I noticed a lot of the caulking around the covers and seams were cracked. Can I just caulk over the existing caulk? It would be a real PITA to remove the old caulking (it is 1" wide and about 1/4" in some places).
RickV is offline   Reply With Quote
Old 11-05-2013, 06:25 AM   #2
simplyrwc's Avatar
I have the same question. I've read on here somewhere that some just remove the loose caulking and then re-caulk. I am prepping to do some myself thanks for starting the thread.
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 11-05-2013, 07:05 AM   #3
TURBS's Avatar
Heat gun and a plastic putty knife is what I used when I installed a fan in my bedroom.
Works fast and easy!
Use dicor self leveling caulk.
Ps the dealer said you "can" clean old caulk really well and just caulk right over existing.
Turbs
Old 11-05-2013, 07:20 AM   #4
Dave_Monica's Avatar
You can add more Dicor caulking to fill in any gaps and touch-ups. You could also look at putting Eternabond (or Dicor) tape over the entire caulked area as a more permanent solution. There's many threads on here discussing that if you use the search function.
Dave
Old 11-09-2013, 11:26 AM   #5
Never Leak RV Roofing
I don't understand if the self leveling caulking is cracking, then why re-install the same product back on? Take off the Dicor self leveling caulking with a dull putty knife, then acetone to clean then use a 4" fiber back seam tape to cover all screws, this should be done on the front, back, all vents, plumbing and kitchen base. You want to use a 4" Seam tape that is going to accept your roof coating, never have a leak again. It works here in Florida....
rvroofer is offline   Reply With Quote
Old 11-09-2013, 11:38 AM   #6
Ford Idaho's Avatar
I would like to know why it was necessary to use that much caulking material in the first place.
Old 11-09-2013, 12:08 PM   #7
TURBS's Avatar
I don't understand you post?
Turbs
Old 11-09-2013, 12:12 PM   #8
Ford Idaho's Avatar
Turbs
Is this amount of caulking normal?
I think that much is excessive and unnecessary.
Old 11-09-2013, 12:26 PM   #9
TURBS's Avatar
Look at my post of pictures when I installed my vent fan .
That is normal.
Old 11-09-2013, 07:18 PM   #10
Denver, CO
garbonz's Avatar
Dey use BIG caulking gun and go real fast, hence the pump a pretty big bead, Remove it, caulk over it, put eternabond on; it will all work. The caulks weather and need to be cleaned and the eternabond last longer, or so I have heard.
Pick one and do it.
Der you go.
2017 Fuse 23T
