Old 03-30-2015, 02:19 AM   #1
Caulking Side Wall Of RV
This is for a Sunseeker class C.
The first picture is of the side in the cab over area.
It definitely needs caulk.
Questions (sorry in advance but I'm a newbie so want to do it right):
- What kind of caulk do I use? A dealer gave me a tube (second picture) but the directions pretty clearly say it's basically for roofs.
- Do I remove the caulk that's there? And if so, how? I don't really want to scrape at it with a putty knife as that will mark up the side.
Thanks!
Name:	ImageUploadedByForest River Forums1427696351.559723.jpg
Name:	ImageUploadedByForest River Forums1427696366.648891.jpg
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 03-30-2015, 06:58 AM   #2
Canadian Member
You're right to not use that caulk for the window. That caulk is the "self levelling" type. You need something like Proflex RV Sealant for the vertical walls.
ProFlex RV Flexible Sealant - Bright White - Geocel 28127 - Roof Maintenance & Repair - Camping World
I wouldn't scrape the old cracked sealant off unless there is some loose spots. Just apply the new caulk over the old.
2019 Rockwood Signature 8290BS
Old 03-30-2015, 07:45 AM   #3
I would definitely very carefully remove the old caulk with a plastic blade, blow out the debris, wipe with acetone and re-caulk. Otherwise, you will never get a smooth finish or fill the voids.
Old 04-02-2015, 06:42 PM   #4
Never Leak RV Roofing
Thanks!
Attachment 72518
Attachment 72519
Take a dull putty knife on an angle to get the old caulking off, then pro-flex...
rvroofer is offline   Reply With Quote
Old 04-04-2015, 07:28 PM   #5
OP here with an update. Thanks for everyone's advice. I picked up some plastic caulk removal tools, Goo Gone (saw on another forum that acetone wasn't recommended as it could damage fiberglass), and ProFlex. I scraped off the caulk that was loose. Some of the caulk is still firmly attached (in the picture below my finger). I was scraping hard and was only getting maybe a millimeter of caulk at a time. So I think I'm going to caulk the whole seam - the part where I removed the caulk and the part with most of the caulk still there (will just go over the existing caulk there). I am surprised how thin a line the original caulk from the plant is.
Attachment 73078
Name:	ImageUploadedByForest River Forums1428189999.841310.jpg
caulk
