Old 06-06-2017, 06:30 PM   #1
Alberta8311ss's Avatar
Check your tires
ID:	140341Click image for larger version
ID:	140342Click image for larger version
All four of our oem tires had cracked sidewalks this year. Tire is dated 2013, bought rockwood in 2015 (2014 model year). Cannot believe what garbage they are. I have other utility trailers that get more use and have older tires in better shape than these! I ordered new tires in and the day I went to take the oem ones off one was leaking air out the sidewall. These tires are covered when not in use so it was not the sun. I went from a range "c" to range "e" Carlisle HD tire.Click image for larger version
ID:	140344Click image for larger version
Sure am hoping to get more life out of these. Heavier tire for sure, look forward to see how it will tow down the road. I am hoping for less rolling resistance.
Alberta8311ss is offline   Reply With Quote
Old 06-06-2017, 07:05 PM   #2
Livnlrg1's Avatar
Had the same issue with our 2015 Salem's tires. Went for inspection this year and they were all cracked on the side walls. Went with the class "e" Carlisle HD's as well
Livnlrg1 is offline   Reply With Quote
Old 06-06-2017, 08:58 PM   #3
5er_tom's Avatar
Folks, just go with LT tires so you can worry about something other than tires.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
5er_tom is offline   Reply With Quote
Old 06-07-2017, 05:07 AM   #4
Big1's Avatar
Wow, I need to look at mines, I will be going out and take a look tomorrow.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
Big1 is offline   Reply With Quote
check, tire, tires
