Old 09-03-2015, 10:06 PM   #1
Just a member
kandl's Avatar
Check your vent lids!
Nasty rain storm last night – little bit of hail too. Checked the TT interior afterwards and noticed some water directly below the kitchen and bedroom vents. That’s odd because they were closed. Fired a big beam through the bug screens and couldn’t really see anything amiss but it was dark and it was getting late. Storm had moved on.
Went out this morning to have a better look and lo and behold, I could see daylight through the hinge end of the kitchen vent lid. The bedroom lid was even worse. Hail wasn’t bad – just pea sized stuff (small peas). These lids are OEM and are the Heng’s Industries variety. They’ve seen all but five seasons. They passed visual and were watertight in Jul when the roof was last cleaned. When I got them off it was apparent that the lid material was literally crumbling. The lid depicted was from the bedroom and what’s interesting about that is that it was in worse shape than the kitchen vent lid and the bedroom vent was rarely ever opened.
Anyway, check your vent lids and...
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge Ram 3500
kandl is offline   Reply With Quote
Old 09-03-2015, 10:11 PM   #2
Plain Old Member
Maxx Air II covers. Vent lid saver.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-03-2015, 10:25 PM   #3
Just a member
kandl's Avatar
Indeed, pondered that. Repondering...
Old 09-03-2015, 10:30 PM   #4
Explorer
My trailer is a 2011 as well and mine came apart last spring. I keep our trailer under a cover when not in use, I would think FR could have used a better material.
I added the Campingworld travel cover while I was up there.
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 09-03-2015, 10:49 PM   #5
Just a member
kandl's Avatar
Originally Posted by YoungKopernik View Post
...I would think FR could have used a better material.
I'm thinking precisely that. Especially for something that is exposed daily to that big ball of fire. Except maybe for the five months they hibernate under the snow.
A Maxxair II is nearly $80 in this neck of the woods. Even the original style is over $50. I can get a vent lid for less than $20 and even if I have to change them every three/four years, the CBA is not favoring additional covers.
Old 09-04-2015, 06:16 AM   #6
TURBS's Avatar
Don't buy the max air II vents
Buy the new and improved maxx air vent covers.
"Fan mate"
http://www.maxxair.com/products/fan_mate.php
ID:	87770Click image for larger version
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 09-04-2015, 06:28 AM   #7
Better yet buy a NEW Rockwood or Flagstaff and they come from the Factory with Max Air Fan Mates! Youroo!! Very Old School to Not use Covers over any CHEAP lids! Broken lids allow WATER to enter your unit!
Name:	DSCF4598 - Copy.jpg
Old 09-04-2015, 06:34 AM   #8
"Fan mate"
Airxcel | Maxxair | FANMATE
Attachment 87770Attachment 87771
TURBS
2011 32bhok Sabre
The Original Max Air or the Max Air II are FINE if the unit you are covering is just a VENT! If it is a Fan Power Vent the Go with the New Improved Fan Mate style! Youroo!!
Old 09-04-2015, 06:39 AM   #9
TURBS's Avatar
How many of your non fan vents have a "fan mate" ?
TURBS
2011 32bhok Sabre
Old 09-04-2015, 06:51 AM   #10
PhoneDude 8289's Avatar
I have the Max Air covers on our vents. Still had water in the living area of the RV after forgetting to close a vent and running it through a truck wash after a month long trip a couple of weeks ago. Wasn't much water, easy to clean up but still had water in the rv. That truck was sure gives the RV a good cleaning roof included.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-04-2015, 06:57 AM   #11
I think they have a Disclaimer about Not using a Fire Hose directly at the Max Covers or Driving backwards in the Rain at High Speed also! Youroo!!
Old 09-04-2015, 12:03 PM   #12
Stormrider151's Avatar
I have the Maxair II covers on my vents. We've had driving rain and no water comes in. I leave the vents open all the time to keep air circulating through the trailer.
Stormrider151 is offline   Reply With Quote
Old 09-04-2015, 12:16 PM   #13
peaceparson
Our last camper had a vent lid go terribly bad. I'm not a chemist, but I wonder if all the sticky sap and other stuff from our black locust tree that accumulates on the top (of everything within 100 feet!) is acidic and causes premature failure of plastic, paint, and other surfaces. I try to wash every surface (camper, cars, tables, etc) two or tree times a year with soapy water to get rid of the sticky, slimy crud, but I think the final solution is going to be the end of that tree.
peaceparson is offline   Reply With Quote
Old 09-04-2015, 12:29 PM   #14
I've found over the years the standard crank vent cover to be poor quality plastic, no matter what brand RV you get, that will easily crack after a few years in the sun. You can quite often see the broken vents flapping in the breeze of the vacuum of the windflow over the trailers with the broken vents during the summer.
EVERY vent now gets a cover, Camco is fine for me, well made and work fine, even put over the Fantastic fans we've had in RV's. Only a bit more work to install and a BUNCH of money saved, like $20 for Camco and $65 for the bells and whistles covers they want you to get for a powered fan vent.
Tdbrn is offline   Reply With Quote
Old 09-04-2015, 12:39 PM   #15
Send a message via AIM to jk31668
like most oem stuff, the mfg. uses the cheapest parts/materials they can. mine did the same thing so went to my local rv guy and had them all replaced with a heavier duty hatch.
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 09-04-2015, 01:14 PM   #16
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
TURBS
2011 32bhok Sabre
I got 3 of them - best purchase ever
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-04-2015, 01:40 PM   #17
Plain Old Member
Maxx Air II works just fine in our application, even with the fan. Ours stays indoors when not in use, so it's not on there to just protect the cover. Blocks light and helps with the heat. As long as you have A cover, that's all that matters. Everybody has their preference on what works for their specific rig.
Old 09-04-2015, 02:14 PM   #18
Georgia Rally Coordinator
aceinspp's Avatar
Older tt or campers did not have all the fancy covers to protect from the UV rays so after about 5 years they disintegrated. Should you buy a new camper without the covers one can use 303 Protectant and it does work well. I also now use it on my new camper to protect the over head sunlight's from frosting over. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 57
aceinspp is online now   Reply With Quote
Old 09-04-2015, 02:41 PM   #19
"Fan mate"
TURBS
2011 32bhok Sabre
what's the difference between this one and the other Max Air vent covers?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 09-04-2015, 02:46 PM   #20
TURBS's Avatar
Better air flow with a vent fan.
TURBS
2011 32bhok Sabre
vent
