Old 04-18-2013, 01:52 PM   #1
Cleaning & Sealing Roof???
2010 Cardinal - How often does roof need cleaning and sealed? What about caulking around A/C, vents, etc?? What is best to clean and seal with? Any suggestions on what to polish exterior with?? Any and all suggestions greatly appreciated!!!! Thanks!!
Cardinal camper is offline   Reply With Quote
Old 04-18-2013, 01:57 PM   #2
Triguy's Avatar
First, its good to ID the type of roof that you have: Rubber roof (AKA “EPDM”) membranes are smooth and will be slippery when wet. TPO roof membranes have a texture like an orange peel.
Basically, the roof needs to be cleaned with a non-petroleum based cleaner. Inspect the seals for cracks and use Dicor LAP sealant to touch-up (leveling for horizontal surfaces and non-leveling for vertical surfaces).
There's more information in our Library for further reading about recommended cleaners and other items for each type of roof.
Forest River Forums - Downloads - Awnings, Roofs and Exterior
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-18-2013, 02:07 PM   #3
Thanks!!! I'll check and make sure type roof!!
Old 04-18-2013, 02:22 PM   #4
Herk7769's Avatar
After cleaning I also use a UV treatment on my TPO roof membrane.
HAM CALLSIGN - KC3FFW
Old 04-18-2013, 02:35 PM   #5
jUST HAD TO HAVE MY ROOF CLEANED AND RESEALED. LOOKS LIKE NEW NOW. ALSO HAD TO REPLACE SOME VENT COVERS THAT THE SUN HAD JUST CRACKED ALL UP. IT IS NOW UNDER A SHED AND i HOPE THAT WILL PROTECT ROOF WHILE INACTIVE..
chevy2500 is offline   Reply With Quote
Old 04-19-2013, 06:57 PM   #6
chiefscamp's Avatar
Can you stand on the roof or should you put up some planks?
Richie
chiefscamp is offline   Reply With Quote
Old 04-20-2013, 05:26 AM   #7
Triguy's Avatar
I've always walked on the roof with no problems and do not use boards.
Scott
2012 Shamrock 233S
