Old 11-04-2010, 01:16 PM   #1
f150k's Avatar
Cleaning roof
I thought I read in our 8280WS Rookwood information that you should clean the roof with Murphy's oil soap, but I can not find it in the roof info now? Also what manufacture supplies the roof material?
f150k is offline   Reply With Quote
Old 11-04-2010, 02:19 PM   #2
M109Rrider's Avatar
Some roof care articles I've read recommend Borax. I tried it and it seem to work as good as anything else.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 11-04-2010, 02:44 PM   #3
realebill's Avatar
i use murphy's oil soap and it does a satisfactory job. i clean the roof at least 2 times a year. you can also use any mild dish detergent. i would never use an abrasive cleaner or a citrus based cleaner. like my rockwood,yours probably has a pvc vinyl roof. regular cleaning is all it needs.
realebill is offline   Reply With Quote
Old 11-04-2010, 03:44 PM   #4
Arn
Arn
Roof Maintenance
This is a good read on roof care. Yours is TPO vinyl so follow those instructions. Not sure if your roof is made by Dicor or Alpha but either way the instructions are the same.
Arn
Arn is offline   Reply With Quote
Old 11-04-2010, 08:41 PM   #5
bmg
Question
This is our first year with the TT and I just cleaned the roof and plan to seal. I used a natural cleaner called Miracle II. We've used it for years for cleaning everything. I even brush my teeth with it. You can dilute it to any strength you need. Straight out of the bottle is the best product I've used to clean motor oil off my hands. No chemicals so it's friendly to me and environment. I found that it worked much better than the Protect All Rubber Roof Cleaner that I bought. That stuff requires rubber gloves and you have to mop up the residue because if you let it spill over the edge it will stain the finish on the sides. With the Miracle II I just scrubbed it lightly with a brush or sponge and then rinsed it off.
I also bought the Protect All Rubber Roof Treatment, but read that it only lasts 3 to 6 months. The Dicor coating says it lasts longer. But they have 2 products. One that cleans and primes and the other that coats. My question is that since I already have a clean roof is it necessary to use their cleaner and primer too or can I just apply the coating?
Rubber Roof Coating on Sale
bmg is offline   Reply With Quote
Old 11-05-2010, 06:59 AM   #6
Murphy Oil Soap was recommended in the paper work that came with our trailer
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 11-05-2010, 07:43 AM   #7
MtnGuy's Avatar
Originally Posted by Arn View Post
Roof Maintenance
Arn
Good article.
5th wheel
