Old 09-26-2007, 09:28 PM   #1
froglegs's Avatar
Cleaning vinyl roof
What do you use to clean the vinyl roof on your camper?
2000 F-150 4x4 sc,off road pkg,Tow Pkg,5.4,3.73TL,2007 Flagstaff 8524RLS,and One Happy Maltese! See You Down The Road!!!
froglegs is offline   Reply With Quote
Old 09-26-2007, 09:45 PM   #2
welshman599's Avatar
Send a message via MSN to welshman599
I'm more familiar with EPDM rubber, but according to Alpha's website (FR uses Alpha's rubber roofs, so maybe it also uses it's TPO vinyl stuff too)
Cleaning and Maintaining the Royal Tuff-Ply Roof
Proper care, cleaning and maintenance of TPO roofing is quite simple due to the basic properties and longevity of the material. Periodic cleaning is the primary maintenance needed. Alpha Systems recommends using Murphy's Oil Soap® with a soft nylon brush or sponge to clean Tuff-Ply.
DO NOT USE SOLID OR GRANULATED CLEANERS, as they will mar the natural finish.
DO NOT USE ARMOR-ALL® OR OTHER OIL OR SOLVENT-BASED CLEANERS, as they will leave a slick surface and possibly damage the membrane.
A thorough cleaning with moderate scrubbing action, per the suggestions above, should remove most stains and keep the roof looking good. For removal of more stubborn stains, contact Alpha Systems Customer Service at (574-295-5206).
Annual roof inspection is recommended. Check the membrane for possible damage and check the caulk or lap sealant used in all termination areas and around all accessories and fasteners.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 10-02-2007, 07:26 PM   #3
Bumping this, as I'm sure someone has advice for Froglegs on vinyl...
Old 10-02-2007, 07:33 PM   #4
I have used Murphy's Oil Soap on my EPDM roof with good success. There are a couple of hard stains that won't come out, but who sees it but birds and passengers in very low flying airplanes anyway. I suspect the birds are responsible for them anyway.
Hokiehall is offline   Reply With Quote
Old 10-02-2007, 07:58 PM   #5
milzat's Avatar
froglegs,
You 2007 Flagstaff does indeed have a Alpha (TPO) Vinyl roof.
The cleaning and maintaining of the thermoplastic polyolefin (TPO) is as welshman599 posted.
Your can visit Alpha Systems Inc. web site HERE .
milzat is offline   Reply With Quote
Old 10-02-2007, 08:04 PM   #6
They must have changed them since 2004 as mine has the EPDM roof along with the instructions on cleaning it with the oil soap.
Old 10-02-2007, 08:06 PM   #7
It wors on rubber too? nice to know. Its fun having guys on their roofs with $60 bucks worth of "rubber roof cleaner" watching me and calculating while I'm doing mine with a sponge mop and a two dollar box of spic & Span.
Old 10-02-2007, 08:19 PM   #8
milzat's Avatar
Yes, they did change to Vinyl on the Rockwood/Flagstaff line. Don't know what year it was changed. I asked the techs at the dealership, but that's like talking to a brick. Dah...
The cleaning instructions came with my Rockwood also.
