Old 10-04-2012, 05:00 PM   #1
troyt's Avatar
CorPlast Underbelly
Has anyone attempted to remove the CorPlast material from under their TT or RV. I'm considering adding another fresh water tank and I'm not real excited about removing the underbelly panels just to see if I can squeeze in another tank. I intend on putting it back when I'm done. I have read other posts about put a "tin roof" under there.
Anyone have any tips to tricks or thoughts in the matter?
2017 Dodge 2500 Crew Cab 6.7L Cummins 4X4 38k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (10) 2018 (10)
troyt is offline   Reply With Quote
Old 10-04-2012, 06:22 PM   #2
TURBS's Avatar
its just held on by screws and turn bar . Its really not that difficult .
keep in mind you may be over your hitch weight or your tt overall weight by installing another fw tank and hauling trailer with both tanks full .
two 30 lb tanks is 480 lbs when full .
TURBS
Old 10-04-2012, 10:42 PM   #3
troyt's Avatar
Good thought. I normally travel with little to no water to CG. Fill at CG. Just run out a little quick with 4 to 6 adults. My 43 gal tank seem to go quick. I figure I only need about another 20 and still keep in good shape with the 38 gal gray and black tanks.
Old 10-05-2012, 05:52 AM   #4
TURBS
And I always thought 2 x 30 = 60. Must be modern math to get 480.
Old 10-05-2012, 06:36 AM   #5
TURBS's Avatar
Meant two 30 gallon tanks weight 480 lbs when full of water
Old 10-05-2012, 07:01 AM   #6
2 X 30 X 8.345 = 500.7
Just gotta mess with ya Turbs!
Old 10-05-2012, 07:06 AM   #7
mike54's Avatar
how about this
Portable RV Fresh Water Tank: 45 Gallon - New World Mfg CW1605 - Fresh Water Tanks - Camping World
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 10-05-2012, 07:16 AM   #8
Wanna Be Camper
SaskCampers's Avatar
I think Mike's idea would be a much better way to go. Far less work as well as you have no additional plumbing to do, just get a transfer pump to speed up moving water to the trailer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 10-05-2012, 07:20 AM   #9
TURBS's Avatar
Wouldn't be right if you didn't my friend!
Old 10-05-2012, 07:35 AM   #10
Herk7769's Avatar
I did mine front and back to run some wires.
My only tip?
DO NOT PICK A WINDY DAY
HAM CALLSIGN - KC3FFW
Old 10-06-2012, 07:48 AM   #11
DannyKAK's Avatar
Herk when you removed the underbelly can you see the water lines?
DannyKAK is offline   Reply With Quote
Old 10-06-2012, 08:00 AM   #12
Wanna Be Camper
Not sure what floor plan this unit is, but it should give you a bit of an idea where stuff is in the belly.
ID:	20277   Click image for larger version
ID:	20278   Click image for larger version
John & Deb
Old 10-06-2012, 11:25 AM   #13
Herk7769's Avatar
There are almost no water lines accessible from below (just the sewer lines) in my camper (a 5th wheel). The water system is entirely behind the kitchen cabinets and in the overhead of the "basement".
Name:	6 June 2009 025.jpg
Old 10-09-2012, 10:03 PM   #14
DannyKAK's Avatar
Thanks Herk I broke down and hired someone to fix my problem
underbelly
