I have a 3006WK that's not even two years old. I was cleaning my awning at home and discovered a crack in the fiberglass above the entry door coming down about three inches from the awning track. Has anyone seen a case like this and what can I do? Is this something that will be covered by warranty or is this common?
What year?.....what manufacturer?......Are you still within the warranty period?
2014 Prime Time Sanibel 3250
In the Past WJ with slides on each side had Cracks appear at the Top of slide opening,F/R would replace the "Entire Side Wall"! What have they said about this situation? Youroo!! Is this the Front or Back Door?
