Old 03-22-2014, 11:38 AM   #1
Davanator's Avatar
Crack in front nose piece
I have a 2006 Flagstaff 24' fifth wheel and the front nose piece/panel has developed a crack that extends from the bottom trim upwards towards the middle of the panel. It has been parked since last fall. I'm wondering if there is a way to fix it or will I need to take it to the factory to have the whole panel replaced, and would anyone know what that might cost? I have attached a photo for reference.
Thanks for any information anyone can share.
Davanator is offline   Reply With Quote
Old 03-22-2014, 01:04 PM   #2
Lloydg's Avatar
Have you checked your insurance? Just a thought.
2013 Surveyor SVF 293
2013 Ford SD F250 4x4 SC; 6.2 EFI V8
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 03-22-2014, 01:26 PM   #3
Drill a small hole at both ends of the crack. This will prevent it from getting larger. If the cap is made of fiberglass, it can be repaired. If it is plastic, don't know about repairing it. If you are handy, you can purchase a fiberglass repair kit and do it yourself. If not, most auto body shops can repair it (a lot of fiberglass parts are put on cars). Hope this helps.
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 03-22-2014, 02:06 PM   #4
If it were me, I would make a serious effort to go to the Goshen Rally and fill out a Service form.
Old 03-22-2014, 02:20 PM   #5
Went to a bike show here in Montreal a few weeks back and there was a company that repaired plastic and did a pretty good jod. I suggest you google in your area for Plastic repair or plastic fix and you will probably find a similar company in your part of the world... good luk....
micalo is offline   Reply With Quote
Old 03-22-2014, 06:46 PM   #6
Davanator's Avatar
Thanks for the reminder. filed a claim, we will see what happens.
