05-25-2019, 12:30 PM
Cracked and loose outside trim piece
We have a 2017 Rockwood Mini-Lite 1905 and the Rubber trim on the left side of the trailer at the top cracked and the trim rail is now exposed. Does not look like it would cause a leak but i put sealant on a few of the screws but would like to see where i can get the rubber trim to replace it. I have emailed Rockwood to see where I can get the parts.
Fivebuccs
BBQ and chili cook
Retired Railroader
2017 Mini-lite 1905
2020 RAM 1500 Bighorn 5.7 Hemi
05-25-2019, 01:24 PM
2016 Salem 27RKSS
05-28-2019, 07:26 AM
vinyl trim insert
I have a 2017 21ss shamrock and need the vinyl trim insert for the front corners. Does anyone know the size before I remove. Looks like 3/4".
05-28-2019, 07:48 AM
The only way to know for sure what size is to pull a small section out of the end and measure.
You can find both sizes here:
https://www.walmart.com/ip/Camco-Vin...d=actual_color
and here:
https://www.walmart.com/ip/Camco-Vin...Black/29764302
2016 Salem 27RKSS
05-28-2019, 08:35 AM
RVugrades.com
I need some too! The size of the aluminum slot edge to edge on mine is .650", so is that the .750 or 1 " size? I'm thinking probably the .750". Anybody know fer sure?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
05-28-2019, 08:53 AM
I need to replace one side on mine as well, but haven't got around to it yet. Picked up a roll at the dealer. Service manager recommended to let the new insert sit in the sun for a bit to soften up.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
05-28-2019, 09:18 AM
Originally Posted by jeff64
RVugrades.com
I can only say with certainty that 1" has two lips, each 3/16", and the rounded portion is 5/8". I've also found out that this insert stripping does contract and expand with cold and hot ambient temps respectively.
2016 Salem 27RKSS
05-28-2019, 09:28 AM
Standard is 1" don't see 3/4 to much
05-28-2019, 09:38 AM
NOTE: Cut it long, Do NOT stretch it while installing. The material will shrink with time and if you cut it to exact length, next year it will be too short and the end screws exposed again.
05-28-2019, 09:58 AM
I Have attached a pic with a ruler. I also have a gap of just over 1/2". Can not see how 1" would fit.
I might just get both and return the other.
05-28-2019, 12:01 PM
it doesn't go in flat but curved .
05-28-2019, 01:58 PM
I just replaced mine
I just replaced that this trim on my 2016 Salem lite. It is the 3/4 size. The only problem I had was the RV armor roof covered the top part. I just trimmed the new material and slipped it under the old then sealed the gap with Flex Seal. I replaced it all down the front to the screwed in cap on the bottom. It was very easy and I didn’t need any special tools. The trailer is a 201BHXL.
05-28-2019, 02:08 PM
To all that have responded, Thanks. I do have an e-mail into FR support on the actually size for the 2017 Shamrock. I will let you know the outcome. Fingers crossed on a return e-mail. My bet is it is 3/4". Any takers.
05-28-2019, 02:31 PM
Thanks to everyone I send an email not Forest River and they have answered me and asked for some pictures which I sent and I am waiting on them to advise which size to buy.
Everyone have a safe week
Fivebuccs
BBQ and chili cook
Retired Railroader
2017 Mini-lite 1905
05-28-2019, 02:58 PM
When I ha to replace some of that in my old trailer, I just pinched it together and slipped the edges under the flange. Went right in. Did find a leak in the screw holes, though. Unscrewed each screw and put a dab of sealant on it and screwed it back in. No more leaks.
05-28-2019, 05:32 PM
I've found that starting one edge under the metal lip, squeezing the vinal together and running the other side in with a metal tablespoon, the installation goes fast. Be sure to secure the ends! Don't ask how I found out to secure both ends! LOL!
05-28-2019, 05:57 PM
I replaced one whole side on mine, I found that if you leave out in the sun to heat up it becomes pliable and easier to bend into place.
05-28-2019, 06:27 PM
Cut it long!
It also shrinks lengthwise over time. Cut the new trim long, maybe an inch for every 10 feet. In a year or two it will be a perfect fit.
This trim is also readily available on eBay for attractive prices.
Larry
05-28-2019, 07:57 PM
SafetyCamper
Exterior Trim Molding
I just went through this on my 2016 Ultra V 2715VS... It was 1 inch wide... only comes in white and black that I have found at CW. Really an easy fix and only took a few minutes. Out of curiosity, I check a few of the screws... and most had worked a bit loose. I snugged them up and put on the new trim! All good! Good Luck and Safe Travels! JW
