Old 05-25-2019, 12:30 PM   #1
Fivebuccs's Avatar
Cracked and loose outside trim piece
We have a 2017 Rockwood Mini-Lite 1905 and the Rubber trim on the left side of the trailer at the top cracked and the trim rail is now exposed. Does not look like it would cause a leak but i put sealant on a few of the screws but would like to see where i can get the rubber trim to replace it. I have emailed Rockwood to see where I can get the parts.
Fivebuccs
2017 Mini-lite 1905
2016 Toyota 4 Runner
Fivebuccs is offline   Reply With Quote
Old 05-25-2019, 12:49 PM   #2
007matman's Avatar
Check the size but this should do it.
Camco 25212 Vinyl Trim Insert (1" x 100', Black) https://www.amazon.com/dp/B000EDSSCU..._r.x6CbWVBF3YT
007matman is offline   Reply With Quote
Old 05-25-2019, 01:24 PM   #3
D W
D W's Avatar
https://www.walmart.com/ip/Camco-Vin...Black/29764302
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 05-28-2019, 07:26 AM   #4
vinyl trim insert
I have a 2017 21ss shamrock and need the vinyl trim insert for the front corners. Does anyone know the size before I remove. Looks like 3/4".
kdraper is offline   Reply With Quote
Old 05-28-2019, 07:48 AM   #5
D W
D W's Avatar
The only way to know for sure what size is to pull a small section out of the end and measure.
You can find both sizes here:
https://www.walmart.com/ip/Camco-Vin...d=actual_color
and here:
Old 05-28-2019, 08:35 AM   #6
jeff64's Avatar
RVugrades.com
I need some too! The size of the aluminum slot edge to edge on mine is .650", so is that the .750 or 1 " size? I'm thinking probably the .750". Anybody know fer sure?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-28-2019, 08:53 AM   #7
Chief T's Avatar
I need to replace one side on mine as well, but haven't got around to it yet. Picked up a roll at the dealer. Service manager recommended to let the new insert sit in the sun for a bit to soften up.
Safe and happy travels.
2017 Tracer Air 206
2012 GMC Sierra 1500 SLT 6.2l
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 15
Chief T is online now   Reply With Quote
Old 05-28-2019, 09:18 AM   #8
D W
D W's Avatar
Originally Posted by jeff64 View Post
RVugrades.com
I can only say with certainty that 1" has two lips, each 3/16", and the rounded portion is 5/8". I've also found out that this insert stripping does contract and expand with cold and hot ambient temps respectively.
Old 05-28-2019, 09:28 AM   #9
Standard is 1" don't see 3/4 to much
MR.M is offline   Reply With Quote
Old 05-28-2019, 09:38 AM   #10
NOTE: Cut it long, Do NOT stretch it while installing. The material will shrink with time and if you cut it to exact length, next year it will be too short and the end screws exposed again.
TheWolfPaq82 is online now   Reply With Quote
crack
