Old 05-24-2015, 03:11 PM   #1
D shape Water heater cover connector
I have a 2014 Rockwood mini lite and the little d shape connector for the water heater cover broke. Does anyone know the name of it or where to get another one ?
keelidp is offline   Reply With Quote
Old 05-24-2015, 03:21 PM   #2
Mr. Dan's Avatar
Water Heater Latch
I'm not recommending this one or any other... but this shows its name.
RV Camloc Water Heater Latch
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 05-24-2015, 03:34 PM   #3
Camping World
#2280 Set of 2 $6.89 Water Heater Access Door Latch
Probably get them at any RV dealer in your area.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 05-24-2015, 03:39 PM   #4
bubbles's Avatar
There interchangeable but Atwood uses metal and Suburban uses plastic. I think.
Old 05-24-2015, 03:47 PM   #5
Thank you all for the information. Greatly appreciated
Old 05-25-2015, 07:14 AM   #6
cpaulsen's Avatar
My plastic one broke......bought a metal one.
cpaulsen is offline   Reply With Quote
Old 05-25-2015, 04:01 PM   #7
The metal lock tabs tend to rust. That may be why Suburban went to plastic.
DRiveWell is offline   Reply With Quote
Old 05-25-2015, 04:10 PM   #8
Make the D tab and metal loop that catches the spring out of alum and solve the rusting and breaking problems.
Old 06-25-2015, 11:37 AM   #9
2016 Rockwood Ultra-Lite
radarman's Avatar
One trick I have used on water heaters is to open the door and remove one of the top outer seam mounting screws. Then drill a slightly larger matching hole thru the door at the same location as this seam hole. Then use the same screw to go thru the door and into the mounting hole to secure the door. This is an additional door lock in case the main door lock breaks and prevents the door from coming open during travel, etc.
Jim and Connie w/3 lb. Chihuahua= Nugget
2016 Rockwood Ultra-Lite 2608WS
2004 Dodge Ram 2500
radarman is offline   Reply With Quote
cover, heater, water, water heater
