Old 01-21-2013, 11:03 PM   #1
Denver, CO
garbonz's Avatar
Smile Decals
I just picked up a 2013 V-cross 275 VRL and am planning to replace the door to the battery compartment (big compartment, small door) so that I can fit a couple of 6 volt deep cycles batt in there.
I need to replace the decal on that side and need to know where to get them. I figure they should be available since the camper is new.
Any input out there.
Thanks,
Garbonz
Old 01-22-2013, 03:35 AM   #2
puff's Avatar
I have a plotter and can make some decals....which one you looking for..?
Can you post a picture...?
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 01-22-2013, 08:37 AM   #3
Dave_Monica's Avatar
You should be able to order the decal you need through the V-Cross parts department. I don't know the number, perhaps you could get it through calling the main mumber. They'll need a VIN and a picture of the decal you need to replace.
Dave
Old 01-22-2013, 09:20 AM   #4
Denver, CO
garbonz's Avatar
Pics of Decal
The decal in the lower front edge where the battery compartment door is below the wardrobe slide is the one I need, as the new door will be wider than the current small one and I will have to piece in part of the decal that is cut out and that is on the door.
Old 01-29-2013, 04:08 AM   #5
Denver, CO
garbonz's Avatar
What is the main parts number? My dealer has not responded to my Emails, and if I am going to call, I thought it might as well be FR who should know how to get the decal to me or the dealer
2017 Fuse 23T
Old 01-29-2013, 07:49 AM   #6
I was able to get the part number of replacement decals from the FR factor rep.( That was Sabre Sam in our case!) I then ordered them from the dealer. It turns out that decals are changed often so they needed the Vin Number to make sure I got the right one. ...and I did!
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
