Old 11-20-2015, 12:20 AM   #1
Mike968's Avatar
Dicor roof sealant
There seems to be a few different types of Dicor roof sealant, not sure which one to get for my 2012 Sunseeker.
Amazon has no less than 3 different part numbers for each; lap sealant and the non-sag. Help!
Mike968 is offline   Reply With Quote
Old 11-20-2015, 05:22 AM   #2
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
I used the self-leveling lap sealant below and have had absolutely no problem. I applied it during "the rainy season" while we were camping because there was a leak around my TV antenna area and skylight over the shower.
Despite having only a brief stop in the rain, it sealed perfectly and we've had zero problem.
Dicor Self-Leveling Lap Sealant - Ivory - Dicor 501LSV-1 - Roof Maintenance & Repair - Camping World
Robert & Estha Shiflet
'17 Cardinal 3456RL - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017: 712 ~ Nights Camping 2018: 41
rjshiflet is offline   Reply With Quote
Old 11-20-2015, 05:35 AM   #3
davel1971's Avatar
self leveling for roof, but not walls
David & Lynn
Old 11-20-2015, 05:51 AM   #4
(Dry Huunday)
DreiHunde's Avatar
Yep
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 11-20-2015, 07:59 AM   #5
Head Rambler
Self leveling lap sealant is for horizontal surfaces (i.e. roof), non-sag sealant is for vertical surfaces (i.e. Windows, baggage doors, etc.).
Gotta go campin!
Old 11-20-2015, 04:32 PM   #6
Dicor site preparation
I have a couple of spots on my roof that need to be sealed. How do you prep the site before applying he new Dicor. Does the old need to be stripped off prior to adding the new or is it applied over top of the existing Dicor?
I appreciate the help.
Gilm2113 is offline   Reply With Quote
Old 11-20-2015, 04:49 PM   #7
MTA
You may want to go on dicors website Found out right before I was getting ready to do mine that I had the wrong caulking. There is Edpm and two types of tpo which mine required a solvent and a special caulking. On dicors web Site there are instructions to tell what type of roof you have
MTA is offline   Reply With Quote
Old 11-20-2015, 04:51 PM   #8
Thanks MTA, I will take a look.
Old 11-20-2015, 08:41 PM   #9
I use very little DICOR anymore. I taped my entire roof last month using Eternabond tape and should be good to go for at least 10 years. Dicor usually cracks in 3-4 years and regular inspections should be conducted on anything sealed with Dicor.
If you use it, old dicor area should be scrubbed clean and I often use a hot steel scraping knife to remove as much of it as I can. Be careful not to damage the roof. Be very liberal applying it.
Skyliner is offline   Reply With Quote
Old 11-20-2015, 10:38 PM   #10
Skyliner, did you remove the old dicor before applying the eternabond? Thanks for your time and feedback.
roo, roof
